Thread: Loss Of Power On 3.0 cdti sri - please help
    New Member L.Hamilton's Avatar
    Jun 2011
    Hampshire
    Default Loss Of Power On 3.0 cdti sri - please help
    Hi guys, I'm new to the whole Vauxhall owners club.
    I've recently bought a 3.0 cdti sri, which I love so far. It hasn't given me any problems until the weekend when I went to overtake on the motorway. I experienced a loss of power and symptoms related to fuel starvation, like juddering and engine almost cutting out. It seems to be intermitant, and has no real pattern to when it does it. The car had 3/4 of a tank when it happened, so I know it had enough fuel.
    Any advice or help would be great as I'm not so much of a mechanic to be honest!
    Sounds like a blocked SCV
    Does it feel like occasional braking?
    How long have you had the car?
    Where did you buy it from?
    What sort of warranty do they offer? (if bought from a commercial outlet)
    What is the service history like?
    What was the previous owners reason for sale?
    If the car came with all receipts look for replacement SCV being fitted
    In the short term let the fuel tank drop to 1/4
    Add two complete bottles of diesel fuel injector cleaner (not fuel treatment)
    Fill the tank up
    Drive continuously for at least 200 miles, do not turn the engine off
    Full Member Big Sig's Avatar
    Did you get any warning lights?
    Jun 2011
    Hampshire
    No warning lights I'm afraid.
    Hate to sound thick for asking, but what's an SCV?
    Only had the car 2weeks now, bought from a private sale, older guy. No replacement SCV in previous reciepts. I'll drop the tank and add the injector cleaner for now and see how it goes. Would it be the fuel filter at all mate?
    Thanks very much for the help.
    You won't get them unless it has the update and uprated EMS
    You will only get a warning once the SCV is completely blocked and the fuel flow is below 45%
    Quote Originally Posted by L.Hamilton View Post
    SCV - Suction Control Valve
    There are two on the fuel pump and they control the amount of fuel when the engine is under load
    Not likely to be the fuel filter, but discussed previously, so here is a summary
    The Y30DT engine (up to 2005 3.0 V6 CDTI) has a service interval of 30K miles / 2 years
    The majority use ECO Flex servicing, so see how long to next service (key out of ignition and press odometer reset)
    However, the fuel filter is only designed for 12K miles
    It will last to 20K miles, but from 15K miles onwards it is normally saturated
    The fuel pump is not affected, but dirt could pass, in turn ending up in the SCV
    I too recently swapped to fuel filter renewals of 10K miles
    Jun 2011
    Hampshire
    Awesome mate, i'll make a point of changing the filter too, cos I'm pretty sure that won't have been done for a long time! If none of that work, I'll go straight for the SCV's.
    I'm impressed by how quick people replied on here, so thanks very much, glad I joined!
    As above, what is the service history like?
    Where did you obtain the car from?
    The car should be on ECOFlex servicing, so perform the check above and see how many miles to next service (compare to service history)
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. Power Loss on 3.0 V6 CDTI
    By V6Andy in forum Engine & Drivetrain
    Last Post: 1st March 2010, 23:59
  3. 1.9 CDTI 150 loss of power
    By Nick_206_180 in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 20:57
  4. loss of power 150 cdti
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 17th May 2008, 14:24
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
vectra c y30dt loss of power under load
