Results 1 to 10 of 21
Thread: New EGR but.............
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default New EGR but.............
    Hi All,
    I had a new EGR fitted about 2 weeks ago which removed the engine management light, however since it was fitted, between 1500-2500 revs the car judders occasionly. I do know I need new Glo-plugs but it seems odd this has only started since having the new EGR fitted. Does the 120 suffer from the 3rd injection wiring problem like the 150's?
    Steve
    May 2008
    manchester
    Quote Originally Posted by vectra 120 View Post
    Hi All,
    Steve
    Hi Mate
    Check out the how to on cleaning the Boost Sensor, my story was exactly same as yours, now sorted!
    Ok m8 thanks done this before but not with the new EGR
    Steve
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    First off I would say get it back to them. The car has developed a judder that wasn't there before. I had a judder at 2,000rpm and it was the EGR valve. Personally I wouldn't touch the engine otherwise until the people who have supposedly fixed it confirm if that's the problem or not.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    You may need a software update to allow the newer type of EGR to work properly
    More in this thread:-
    http://www.vectra-c.com/forum/showth...light=software
    HIH, good luck
    Damo
    Thanks for the info
    Steve
    Right I have a op com read out
    DIAGNOSTIC REPORT:
    OP-COM 081016
    Please add your workshop
    name in the settings window
    **********************ECU ID STARTS**********************
    Source Address: CIM
    Source Address: 0x00000245
    Identifier: 0x0014
    Part Number:13162135
    Software version number: 12244872_
    System description: DELPH0400
    Alpha code:
    Manufacturing date: 050614
    No fault codes stored.
    **********************ECU ID ENDS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x0730
    System name: Z19DT
    VIN: W0L0ZCF6851141635
    Hardware number:81011914
    Part Number:55193968
    Software version number: VJLMS060_S
    System description: BOSCH0100
    Type approval number: B04018
    Alpha code: YZ
    Identifier: 0x0730
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x0103
    Hardware number:0
    Part Number:13172568
    Software version number: 0348C726
    System name: ABSMEBC430
    System description: TRW 0300
    Alpha code: GU
    Source Address: EHPS
    Source Address: 0x00000244
    Identifier: 0x0104
    Hardware number:24444336
    Part Number:0
    Software version number: V21_
    System name: EHPS GEN3 TRW
    Alpha code:
    Source Address: IPC
    Source Address: 0x00000255
    Identifier: 0x0102
    Part Number:13186673
    Software version number: 8.39 16/03
    System description: VDO 0400
    Alpha code: CT
    Manufacturing date: 050622
    Source Address: AIRBAG SDM
    Source Address: 0x00000257
    Identifier: 0x0101
    Part Number:13170590
    Software version number: 0C0C3303
    Alpha code: DW
    Source Address: BCM
    Source Address: 0x00000252
    Identifier: 0x0208
    Part Number:13199492
    Software version number: C13C96 13041704
    System description: TEMIC04
    Alpha code: KD
    Manufacturing date: 000500060108
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0104
    Part Number:13189921
    Software version number: 00000BBD
    System name: REC
    System description: LEAR 0400
    Alpha code: ER
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0104
    Part Number:13198102
    Software version number: 00000BBC
    System name: UEC
    Alpha code: FL
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0105
    Part Number:13193368
    Software version number: OP1D 192000
    System description: SIEM 0401
    Alpha code: JQ
    Manufacturing date: 226050
    Source Address: PDM
    Source Address: 0x00000258
    Identifier: 0x0105
    Part Number:13193369
    Alpha code: JR
    Manufacturing date: 216050
    Source Address: EHU
    Source Address: 0x00000241
    Identifier: 0x0205
    Hardware number:13190730
    Part Number:13190853
    Software version number: 01.11/-----
    System name: CD 30
    System description: BOSCH0400
    Alpha code: MB
    Manufacturing date: 20050616
    Source Address: DIS
    Source Address: 0x00000246
    Identifier: 0x1001
    Hardware number:13208081
    Part Number:13208193
    Software version number: 4176a/-----
    System name: TID Epsilon
    System description: BORG 0400
    Alpha code: AY
    Manufacturing date: 20050614
    I have put the sofware in red could someone work out if I need a update with this
    Steve
    The only code I have on the car is
    0380 - Glow Device General Error
    (08) - Present
    So I need my glow plugs done but this should not make the car judder would it?
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Have you unplugged the EGR and seen if the judder goes away?
    If so then its likely to be a problem with the new EGR and you may need the software update. AFAIK only VX dealers can check for and do the update.
    If not then it could be a dirty boost sensor (MAP), maybe the throttle valve needs cleaning or it has dodgy soldering (there is a how2 on fixing this). Its also possible its the injector wiring, but I thought that would create bad hesitations and even engine shut downs.
    Quote Originally Posted by Marky View Post
    Thanks m8 going back to the garage a week on thursday to fix my boot so he going to have a look and stick it on the computer to see if any new codes come up
    Steve
    update
    car still juddering had window down and listened and its like a whoosing sound on and off between 2nd and 3rd gears. Any ideas?
