Results 1 to 10 of 13
Thread: 2.8V6 bonnet release ....do it now !!
    WGAF#5
    Default 2.8V6 bonnet release ....do it now !!
    A word of warning to those of you with 2.8V6's and "loose bonnet releases"
    GET THEM ADJUSTED BEFORE IT FAILS YOU !!
    at the weekend i realized my bonnet release had failed ....... i had noticed last week on the levels checks that the handle came out a little further than normal and didn't seem to return correctly ...but thought no more of it until it was too late
    having read the HOW2's and what others had accomplished i realized that there is little to no space for access from underneath on the 2.8v6's access is even more difficult if you have fitted an irmy grille
    if indeed yours does fail you ...the only way to gain access to the release is indeed to remove the top grille then remove the rubber "splash shield" so you can access the manual release
    the worst part is you can physically see the releaser handle and operate it via the gap bewteen the bonnet and grille ... but not operate the release like you need to
    i did manage to get mine out without any damage ... I'm not going to say how on an open forum but if anyone does indeed get stuck with a facelift irmy grille I'll happily talk you through what I did BUT it will make your two veg disappear back up into your body and you will wince at the idea of having to do it to your pride and joy
    New Member Tmd's Avatar
    May 2011
    UK
    Thanks for the nudge, what do you mean exactly by loose? Do you mean that the cable on the lever feels slack not taught when you pull it inside the footwell in the car?
    WGAF#5
    exactly that ... the handle should spring back to the closed position after its been pulled almost flush
    Regular Member PORKBALLS29's Avatar
    Epping
    Sir Bob did mine at the Luton meet so I'm ok. :-)
    May 2011
    UK
    Thanks, will take a look at it
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    I dont know, some of us go to the trouble of doing how2's to help prevent these things too
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Is this a problem just at the 2,8? Or every models?
    WGAF#5
    lol i know ... facepalm failure on my part.... i should have known better ... but its one of those .... wet/rainey - it will wait till next time moments that SHOUD not have occurred
    Quote Originally Posted by zafira View Post
    every model will have the issue - BUT the smaller the lump the easier the access to get to the release handle ... for example preface 2.0 can be seen from underneath - but the 2.8 is so large the access space is minmal as the angle increases towards the top of the engine bay
    Quote Originally Posted by PORKBALLS29 View Post
    jammy git Howard
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Thanks for the info buddy... did notice that mine has some slack in it as said (moved out around 1cm without tension)...
    Where did you get the new one from? How much and is it an easy replacement?
    Regular Member Jezzy's Avatar
    S.E
    And you didn't feel ashamed at getting someone so much older than you to do your hard graft for you?
  1. bonnet release
    By Pete Elite in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2015, 00:27
  2. bonnet release cable,,,AGAIN!!!!!
    By collyb in forum Bodywork & Interior
    Last Post: 25th June 2012, 08:49
  3. Bonnet release
    By Admishere in forum Bodywork & Interior
    Last Post: 23rd March 2011, 15:26
  4. bonnet release
    By ade0303 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 20:39
  5. bonnet release
    By magpie27 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2009, 14:08
