Thread: Suspension Height - Figures Needed
    spoons
    Guest
    Default Suspension Height - Figures Needed
    Morning all,
    We've got a few cars running different suspension setups on here and I wanted to ask if you would measure your cars ride height and maybe a picture of your setup.
    The measurement should be taken in mm, front and rear from the centre of the wheel to the wheel arch, making sure you are on flat ground and your measurement is vertical.
    So...
    Car Type & Engine = ??
    Front Nearside = ?? mm
    Front Offside = ?? mm
    Rear Nearside = ?? mm
    Rear Offside = ?? mm
    Suspension = ?? (can you also include roughly how long the suspension has been on the car and how many miles its done)
    spoons
    Guest
    Here's mine:-
    Vectra VXR 2.8 Turbo
    Front Nearside = 325 mm
    Front Offside = 325 mm
    Rear Nearside = 325 mm
    Rear Offside = 325 mm
    Suspension = KW Variant 2 INOX Coilovers (8 months old and 5,000 miles covered)
    Regular Member ian1401's Avatar
    May 2011
    Exeter
    Has the sri lower suspension?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by ian1401 View Post
    15mm lower than standard
    May 2011
    Exeter
    Thumbs up
    Quote Originally Posted by s_zigmond View Post
    Thanks for that
    Cheshire
    Here's mine:-
    Vectra GSI 3.2
    Front Nearside = 370 mm
    Front Offside = 365 mm
    Rear Nearside = 350 mm
    Rear Offside = 345 mm
    Suspension = Eibach / Bilstein B6
    I am not sure why mine is lower at the driver side! i wasn't in it!
    spoons
    Guest
    Quote Originally Posted by paul667 View Post
    Could be fuel weight or the car wasnt on a dead even surface.
    Just turn the car around (so its opposite direct but in the same place), then do the measurements again and see what they say
    london
    measured of the ground as it is easier than guessing the centre of the wheel
    667 rear both sides
    677front both sides
    vxr spec springs from lesjofors and monroe shocks
    about 6 months on the car i think and done about 4k
    london
    Here's mine:-
    Vectra GSI 3.2
    must be sat on a slant- or you've dropped loads of change down the side lol
  1. Quick help needed - Suspension noises after fitting FKs!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 27th June 2012, 18:08
  2. Suspension parts - help and advice needed
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2012, 14:54
  3. Advice needed - How to change vectra c rear suspension arms
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2010, 12:06
  4. Signum Suspension Height
    By s1nglef1sh in forum Handling & Braking
    Last Post: 28th January 2009, 15:54
  5. Suspension height difference
    By Baz07 in forum Handling & Braking
    Last Post: 18th March 2008, 00:46
vauxhall vectra vxr suspension height
