Thread: 2.0dti Diesel pump advice urgently needed
    Regular Member ads3's Avatar
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    confused 2.0dti Diesel pump advice urgently needed
    My 2005 2.0dti, 60,000 miles, is in having a new turbo fitted and the dealer has come back and said oil was found in my diesel pump which was only replaced 6 months ago, they also said there was a knocking coming from the pump when it was cold. It has been sent away to get tested and apparently no fault was found.
    It can't be flushed out either.
    1. Where could the oil be coming from? (When the pump was changed the dealer said it's not uncommon for oil to get 'dumped' into the fuel - is this correct?)
    2. If there is engine oil in the pump what damage could it do?
    3. Surely this oil would just mix with the diesel and burn away?
    Your advice / suggestions / answers are all greatly appreciated.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Oil would get into the fuel through leaking injector seals I'd say.
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    The dealer did say they were going to replace the seals as a precaution. I'm just worried about any damage this may have done to the pump as the engine oil was due to be changed as it's about 12 months old.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I don't think engine oil would damage the pump to such extent that it would die. In any case though, oil in diesel certainly isn't good. Being a DTi the injector seals would've been bad soon so might as well replace those as advised by your dealer.
  1. Z22YH high pressure fuel pump needed urgently!
    By simp_2.2sri in forum Engine & Drivetrain
    Last Post: 27th April 2011, 22:18
  2. heater help and advice needed urgently
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 21:40
  3. Dead Diesel pump 2.0DTI - options????
    By myveccy in forum Engine & Drivetrain
    Last Post: 23rd October 2010, 00:37
  4. Gearbox Oil Level Advice Urgently Needed Please **
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 19:02
  5. Help & Advice Urgently Needed
    By lfcfan85 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th November 2009, 20:05
