Results 1 to 10 of 15
Thread: Grinding noise from the rear breaks
    Nov 2009
    Stockton-on-tees
    Default Grinding noise from the rear breaks
    Hi all, I hope someone can advice me on my problem with my Vectra.
    I have recently noticed a bad grinding sound coming from the rear wheels. It is quite evident on when I break from 30mph to 10mph. Also, when I start the car from cold sometimes it feels like the rear caliper sticks for a while. When the breaks worm up a bit after some driving the grinding noise reduces and its less obvious. I don't think I can hear any noise if I'm breaking from 70mph to 30mph, but as soon as the car start stopping the noise appears again.
    I also, think that the handling of the car became poor in the last couple of months, not much grip in the corners and especially under breaking sometimes it feels like I loose control of the steering wheel.
    I went to the Vauxhall garage two weeks ago to check the car but they said there was nothing wrong. Even one of the mechanics came for a test drive, but at that particular time the grading noise was not very loud and he said thats normal... The car still has some manufacture warranty left I'm thinking that VX might be hiding something.
    I would appreciate if someone can advice me what else I can go with and ask VX to check or reinspect again.
    Thank you in advance
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    check the inside of the rear disc and pads, my XP2 eat the inner side of the rears within 25k ?
    worth checking
    Nov 2009
    Stockton-on-tees
    Disks have been check by VX garage and pads have 1/2 left in them.
    Also, I forgot to mention some other issues I'm noticing for quite a while, break pedal vibrating under breaking (or pulsing), also sometimes gets quite firm when braking slowing.
    Vibration in the steering wheel when breaking hard and also the car pulls to left or right
    I really don't know what else could I say to VX as I have been in their garage a few times to inspect all issues I wrote above and every time they say its fine they cant diagnose any problems and that is with 2 VX garages in my area.
    Car booked again for inspection, but I would appreciate if someone on here can advice on what would a cause of all this.
    Regular Member Jackvectra18's Avatar
    Winchester
    Has the car been sat for a long time? The discs might be corroded if the car has been sat and good long drive can sometimes clear off all the surface rust.
    Nov 2009
    Stockton-on-tees
    Quote Originally Posted by Jackvectra18 View Post
    No, I drive it every day , over 50 miles a day. There is no signs of corrosion on the disks.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    and you trust a steeler? get the wheels of and have a look at the inner pad's
    Regular Member PCMALT's Avatar
    Jun 2011
    Peterborough
    Vehicle : Signum V6 CDTI
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    your rear disc's maybe warped which would give you the vibration in the brake pedal
    a simple test to see if they are warped as you wont be able to see by eye is:
    jack the car up and spin the wheel by hand and let it free spin if it squeak's in places or grabs (stops fairly quickly) then your disc's are warped
    for the sticking in the morning (when cold) it may be the caliper sticking when the hand brake is applied.
    when you get the wheels of just lubricate the mechanism on the back of the caliper with WD or something similar as they do tend to stick
    hope this helps
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    How many miles have the brakes done, maybe you just need new discs and pads all round.
    As Vaux have said, they are OK (work as they should, ie, stop you) but that does not mean they can feel crap and make funny noises if they are getting worn.
    Nov 2009
    Stockton-on-tees
    Thanks for the posts so far, I will try PCMALT said this weekend to see if the disks are wraped. Maybe a silly question but can I just jack only one of the wheels and spin it ?
    As for the mileage the car has done 36500 miles, I bought it 1 year old on 12000 and in the service history I found that the rear disks and pads where replaced due to corrosion on 11500 miles. I haven't changed any break pads as every time the car has been in VX garage for health check, they were showing green and in good condition.
    Thornton Dale
    Trim : Limited
    Engine : 125PS
    I have just changed the whole lot on the Vec I've just bought, and its done 36k miles.
    The fronts discs were shot but the pads had loads of lining. Someone did a cheap fix by just putting on new pads when it needed discstoo.
    The rears looked OK, but I thought stuff it and replaced them too.
    £130 for the whole lot at Vax on Trade Club.
  1. grinding noise turning right
    By jon ixi in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2015, 12:08
  2. grinding noise coming from rear wheels
    By pud wayman in forum Suspension, Wheels & Brakes
    Last Post: 21st June 2011, 07:27
  3. signum..grinding noise from rear
    By uaintsinme..right in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2009, 21:47
  4. Strange grinding noise coming from rear wheel
    By sproket in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2009, 22:04
  5. Grinding Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 10th October 2006, 07:52
cause of rear breaks grinding
scraping noise from rear when turning right in my vectra
