Results 1 to 10 of 23
Thread: Gearbox oil and inner cv boot empty
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Default Gearbox oil and inner cv boot empty
    Evening all.
    Couple of bits being done this eve.
    Should the inner cv boot be packed with grease and clipped back up.
    Not entirely sure. Just noticed it today.
    [IMG][/IMG]
    Also, can someone tell me exactly where the plug is to topup the gearbox oil on my GTS. Had a look but not sure if its under battery cover, as not sure where to look. Would assume i have the F17 gearbox.. can this be filled up without taking loads of stuff off.
    Thanks in advance
    Aug 2010
    Leeds
    Yes should have grease in boot, best to pack it the best you can and tie wrap it back on.
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Quote Originally Posted by Bigtee View Post
    k. thanks for that. will pop in and get some in the morning for that.
    Think i found the gear box plug. Sure i saw a how2 on here somewhere on refilling, but not sure if was same gearbox...
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    k. found the fill plug. easy enough... bit of hose and a wee funnel.
    Regular Member tosh23's Avatar
    HULL
    Pack as much cv grease as you can, But if its been like that for a while I would clean everything first just to make sure there's no grit and crap inside the cv joint itself...Tosh
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Quote Originally Posted by tosh23 View Post
    Cheers. not sure on the process here, but will give it a good go. See if i can get clips off in one piece. save me a long morning if i can do that.
    Regular Member hagga's Avatar
    kingswinford
    Quote Originally Posted by MURDO View Post
    cut the clip off, refill with grease, secure boot with cable/zip tie
    Aug 2010
    Leeds
    When the boot is off ie slide it over the drive shaft you will see the inner cv joint, you can clean this with brake cleaner as it's a bearing.
    Clean off any road grime or salts and re pack with high melting point grease.
    Thats get a dollop in your hand and press it into the cv joint lots of it then refit the boot and away you go.
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    confused
    Sorry to hijack thread
    on mine being in for mot- they noticed both inner cv boots totally split......quoted £70 to do both sides, is it a big job,
    thanks in advance
    Quote Originally Posted by hairy31 View Post
    thanks in advance
    to do them properly the drive shafts have to be removed from the vehicle , which means youll lose all gearbox oil
    so £70 for 2 isnt bad
  1. what to do when the bottles are empty
    By opel_estate in forum Comedy & Humour
    Last Post: 8th June 2012, 13:56
  2. russi666....Empty your box
    By blues n twos in forum General Chat
    Last Post: 11th February 2009, 19:26
  3. Empty hole on side of boot space ??
    By cornishpirate in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 08:22
