Thread: Anyone know how to drop the sump of after removing it? ( cdti 150)
    essex
    Eek Anyone know how to drop the sump of after removing it? ( cdti 150)
    Hi guys
    Ive had a horrid oil leak on my veccy cdti 150 since i bought it and it seems to be the sump seal has failed! I have dropped the sump of completely but it seems impossible to get it out as the oil feed pick up is in the way
    Ive been trying everything for the last hour to try and wiggle it out but it doesnt seem possible Is there a method to doin this impossible job???
    Im goin crazy here trying to get it out
    Cheers rich
    essex
    Come on guys!! cant believe theres no one who knows how to do this job when so many have viewed the post!! Im still stuck underneath the car goin crazy trying to workout how to get this off!!
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Is it the downpipe that's stopping you from getting it out past the oil pick up pipe?
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Exhaust and the driveshaft has to gone off I believe
    essex
    No the exhaust downpipe is off the car and ive now released the sub frame and the drivers side engine mount.. Ive tried lifting the engine to get clearance but it clears on the oil pickup side but then wont clear on the other side.. Thing is , i dropped the sub frame hoping it would allow me to lever it down so i can slide it out but the engine is attached to the sub frame so it moves with it when i lift it..
    Tbh, ive given up right now cos i cant see a way to get this off.
    Might have to call someone out me thinks cos im stumped!!
    Sep 2010
    Dumfries, Scotland
    right hand drive shaft needs to come out, and the intermediate so that you can remove the bearing housing, after that it's all the other bits and pieces tying things together.
    essex
    Talking
    Right! This is whats needed to do the job! You first need to remove the exhaust downpipe also the bearing housing bolts ( these can be removed from the sump without removing the drivshaft ( COOL access to the 3 bolts holding it to the sump can be gained from the rear . Once they are removed it simply pulls free ) Then remove all the sump bolts including several hiden ones that go into the gearbox housing ect! Theres an exhaust clamp that need removing also then a breather pipe from the rear of the sump along with a sensor/ Once all this has been done , you then need to remove then 18mm rear sub frame bolts along with the brackets at the rear of the sub frame on each side.. Then the two large sub frame bolts on each side at the front which will loosen the whole sub frame.
    Lastly and the one that got me at took hours to solve
    Remove the large engine mount bolt from the front of the engine ( near the rad) This is the key as it seperates the sub frame from the engine and allows you to pull it down and get access enough to get the sump clear of all the stuff in the way ( need an extra set of hands to pull down whilst you fit up the sump!!!
    What a mare of a job guys to do on your drive but a good learning experience and i saved a small fortune ( vaux called it a 4 spanner job and said i would of looked at paying around £400+ 5 hours roughly
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Nice to see you got there in the end bud. Did the sump on the wifes Punto last year, 18 10mm bolts, break the seal, remove sump, replace, job done. No need to remove front pipe etc... 1 hour start to finish.
  1. Removing stuck sump plug
    By Big Knox in forum Engine & Drivetrain
    Last Post: 29th February 2012, 18:08
  2. 1.9 CDti Oil Sump - Alternative to Vx
    By Rosco88 in forum Engine & Drivetrain
    Last Post: 7th February 2012, 11:46
  3. Stupid sump plug 19 cdti
    By Mopar Man in forum Diesel Engine related
    Last Post: 11th February 2011, 23:05
  4. cdti sump plug and washer?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2008, 23:40
  5. Sump plug location? 3.0 CDTi
    By ziplex in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2006, 22:27
how remove the engine from a vauxhall insignia diesel
opel insignia oil sump remove1.9 cdti sump removal without taking gearbox out1.9 cdti 150 sump rear pipeinsignia sump removalvauxhall insignia sump removalastra cdti sump removalastra cdti 2006 sump replacement opel zafira 19 cdti oil samp remuvinsigina oil sump removal 2.0 cdi 2010
