Thread: insignia washer jets
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    Default insignia washer jets
    just bought off fleabay, nit of an impulse buy, didnt really think about it until i hit 'pay now'. anyway, will these straight swap to my 06 sri facelift? i bloomin hope so now theyre enroute.
    Apr 2011
    Southport
    Quote Originally Posted by disco dan View Post
    'bit of an impulse buy' (dohh!!)
    Jul 2010
    Warrington / Liverpool
    yeah straight swap... they're not as simple to adjust though
    Apr 2011
    Southport
    ahh ok, not just a soeing needle then?
    Regular Member farley2708's Avatar
    antrim n.ireland
    you can buy a special 'tool' on ebay or vx dealers for adjusting them or you can cut the lid of a biro pen into an 'X' which will do the same job
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Fitting is a straight swap as already said. The best tip is to pour hot water on the hose at the joint point - this will soften the hose which will easily come off then.
    Once fitted, I found mine to be fine for line, it was only height that needed adjusting. Again, the hot water helps and then I CAREFULLY used a pair of long nosed pliers to ease the jet up slightly.
    And then when you're all finished count on refilling the washer fluid rather more frequently for the first couple of weeks as you'll be playing a lot due to way better coverage than the old V jets.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    I'll second the hot water idea, mine were a ***** til i did this! And they do a much better job of "scooshing" than the standard ones!
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    i fitted them took me all of 5 mins, came with a free tool as well
    6 Post(s)
    newport
    i bought some of these when i made the mistake of buying a zafira, and never fitted them. might be time to dig them out again if i can remember where i put them lol
  1. insignia washer jets
    By CristianTM in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2014, 21:17
  2. insignia washer jets
    By rozzer2006 in forum Styling
    Last Post: 29th January 2013, 14:58
  3. Insignia Washer Jets
    By 11mallard in forum General Chat
    Last Post: 28th May 2012, 19:55
  4. is there a how 2 for insignia washer jets?
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2012, 17:26
  5. Insignia washer jets
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 22:18
