Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi with ref to my egr valve problem could i blank it off or would it put light on still
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Dont think you can on Dti's i might be wrong though
    Irmscher Insignia CDTI 130
    Regular Member lanky659's Avatar
    Jul 2010
    Abingdon, Oxfordshire
    Jan 2010
    norfolk
    hi thanks for replies , got problem with no power fault codes read egr valve , low boost pressure .glowplugs and cooling fan relay , bloke said that egr valve so i cleaned and lubricated it but car is really low on power took it to bloke to read codes but could not read them and said itcould be egr valve nackered or airflow meter could this be rite and how do i test them thanks
    West
    have you checked around the vac system for any leaks or failing parts?
    Jan 2010
    norfolk
    yhchecked all pipe work , just found price of new egr valve 600 quid , but dont want to get one and thas not it ,
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi octoman, when you cleaned the egr valve did you inspect inside manifold they tend to get gunged up,remove egr and check if it's full of carbon you will get same code,remove manifold and clean.
    Jan 2010
    norfolk
    thanks jonny bravo yh iv had manifold ofand degunked it so it was clean bloke who read codes could be egr valve shot or airflow sensor , can you test these thanks
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
