Thread: Air Con ... again
    Sep 2010
    Default Air Con ... again
    If you read some of my previous threads, you may know I had my car in for a suspected fault with the air conditioning. VX dealer (EH in Hull) stated there was no fault and it simply needed re-gassing. This was only back in early May this year. I use it regularly and didn't feel it was as cold as it should be. Now, only a few weeks later, surprise surprise it doesn't work again - no cold air but still getting the hiss noise when pressing the button.
    Would I be within my rights to take it to an air con specialist to diagnose and hit EH with the bill as when they carried out the re-gas, my car was still under manufacturers warranty... or as I think,... do I have to give them the opportunity to amend and rectify?
    Problem is booking your car in at the dealers is the time you lose, I cant book it in for 12:00 as they don't work like that, you get your car there for 12 and it gets : the next available slot... and as I've experienced the last two time, this is generally 4:00p.m! - being on industrial estates, there are not many options for you to kill an afternoon without disrupting someone else's time to pick you up and take you back...
    Regular Member 1-8clusive's Avatar
    Jun 2009
    sheffield
    I recently had a similar ongoing problem. The main dealer re-gassed my system months ago and charged nearly £70 for the privilege. After a few days the air con stopped working again. I eventually took it back when the car was in for service and told them to check it again – they re filled it again and this time put in some UV dye, when I picked up the car they told me that it was the condenser (front air con radiator) that was punctured so it would cost me £500 to replace, fortunately they didn’t charge me for the second re-gas because they should have picked up the fault first time. I now have a new condenser fitted that was done by an Air con specialist and only cost half of what the dealer quoted.
    If you have paid the dealer for refill and they have failed to diagnose a leak you might be able to get them to check again for free. The Air con specialist who did mine said he had done quite a lot of late model Vectras (08 on) and he thought the condensers were susceptible to damage.
    Sep 2010
    Thing is, I'm self employed so time is money. I can get my local specialists to check in an hour, VX take a full afternoon. Secondly the specialist will no doubtedly do a better job.
    Just annoyed that VX failed to pick this up under warranty.
    I shall be fitting a mesh guard also I think.
    Engine : 1.9 CDTi
    Phone the dealer that did the regas and explain the situation.
    They might give you a hire car or book you a slot.
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    i had the very same problem with my air con system
    my car is under the manufactures plus network q warranty but got charged £75 for regas but was told by vauxhall dealer that if my air con packs up again i can go back get the system repaired then get my money refunded
    its been ok for 6 weeks wish it would pack up then i can get my money back
    11 Post(s)
    Quote Originally Posted by crispy007 View Post
    Slacken off one of the pipe unions with a spanner then.
