Thread: Coolant Sensor Connector - 1.9CDTI
    Aug 2009
    Rossendale
    Default Coolant Sensor Connector - 1.9CDTI
    Has anyone ever had to replace the coolant sensor connector on a 1.9CDTI 8v? If so I'm just wondering where you sourced the connector from as I suspect that Vauxhall will want to sell me a new wiring loom.
    On my car the connector's two wires move in and out ever so slightly - just enough to either break the connection or subject the connection to high resistance intermittently when the car is travelling >30mph. I've tried opening the connector up and packing it to help restrict the movement of the terminals, but the problem still shows intermittently, resulting in either a fault code or rogue readings on the temperature gauge (the thermostat was recently replaced with the revised version, which is when the sensor connection was disturbed and the problem started).
    I am certain that the connector is the problem as I can replicate both faults (and see the wild temperature fluctuations in Op-Com) at standstill by wiggling the connector's wires. I don't suspect the new thermostat as the cabin heater temperature doesn't change when the temperature gauge's needle suddenly drops to the bottom of the scale.
    Chris
    Engine : 1.9 CDTi
    Any pictures of the connector?
    Aug 2009
    Rossendale
    Quote Originally Posted by lee gsi View Post
    Not to hand I'm afraid, but I can take one if it would help. It's the 2-way connector that plugs into the sensor on top of the thermostat housing.
    Chris
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You can get repair kits for most connectors from Vx
    Aug 2009
    Rossendale
    Quote Originally Posted by merikiito View Post
    That's very useful to know. I'll give them a call in the morning and report back with any info I can glean from them as it may help others reading this thread in the future.
    Thanks for your advice...
    Chris
    Aug 2009
    Rossendale
    I spoke to Vauxhall yesterday morning, but they don't appear to sell a repair kit for this particular connector. The advice they gave was to find a connector from a salvage vehicle and splice it into the wiring loom.
    Vectras appear to be uncommon in salvage yards around here (Rossendale). I've tried a local SAAB specialist but it seems that the equivalent connector on the 9-3's equivalent 1.9TiD 120 & 150 engines is slightly different, so the search continues...
    Chris
  1. Coolant Temperature Sensor
    By Basher1 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd October 2012, 22:26
  2. Coolant temp sensor
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2012, 11:54
  3. coolant temp sensor
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 22:27
  4. coolant temp sensor help
    By mrdouglas in forum Vectra C / Signum Troubleshooting
    Last Post: 12th March 2011, 21:01
  5. coolant temp sensor
    By Morephun in forum Engine & Drivetrain
    Last Post: 15th September 2009, 02:27
