Results 1 to 10 of 11
Thread: SMD dash conversion
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default SMD dash conversion
    I'm in the process of changing my dash lighting to blue and red.
    I've done this before in my saloon so I'm familiar with most of it all though it was a few years ago!
    I have a few questions that I'm hoping some of you could answer...
    I've done the heater control panel and headlight switch panel with no problems.
    I've also done the drivers door switch cluster, the leds all light up but when the switch is re assembled they're really dull compared to the other bits i've done, don't remember having this problem with my saloon
    My latest part is the steering wheel controls (3 button type) but I can't tell which position the standard leds are soldered in to copy.
    My new leds have a long leg and a short leg (presumable + & -) but the legs on the standard leds all look the same to me
    Any help on this appreciated!
    Cheers!
    Engine : 1.9 CDTi
    Maybe the leds are just not that bright.
    Wht leds are in the 3 button steering wheel bit? Are they 3mm ones or surface mount?
    Engine : Z20NET
    They're brilliant in the heater control panel and the headlight switch though...
    maybe I need some brighter ones for that cluster.
    Also, the odometer seems to use 4 solder points rather than 2, is there any way to use the ones I have or do I need different leds for this?
    Engine : 1.9 CDTi
    That uses PLCC4.
    On the PLCC4's 3 pins are negative and the other one is positive. If you can work out what is what you can solder a PLCC2 across those pins (Like I did in the GID How2)
    The headlight one is always at full brightness I think, Do you have the dimmer turned down?
    Engine : Z20NET
    no mate dimmer is turned up, do you have the 3 button steering controls?
    I've just ordered some PLCC4's & some PLCC2 90 degrees for the speedo plus some PLCC2's to redo my drivers switch cluster, just been reading a conversion thread, the guy got his smds from crazy leds and his door switch looks 10 times brighter than mine!
    Engine : 1.9 CDTi
    I have the scrolly one in mine.
    Do you know what leds are in your buttons?
    I have some LEDS left at work if you get stuck
    Engine : Z20NET
    They're 3mm l.e.d's mate
    Engine : 1.9 CDTi
    In that case have a look at the inside of the led and match the 'flag' on both leds:
    Engine : Z20NET
    Just the ifo I was looking for mate! Thanks for that
    Engine : Z20NET
    Well, i ordered some PLCC4 SMD's for my GID and odometer, some 90 deg's for the speedo and some PLCC 2's all from crazy l.e.d's!
    I continued my conversion last night and may I just take the oppourtunity to say...
    Like most things you get what you pay for!! I was never happy with my drivers door switch as is was too dull, even in the dark once lit up, the L.E.D's I used were from Ebay and aren't even comparable to the crazy leds items I used last night, the switch is now infinately brighter than what it was so very happy with that now!
    Also redone my steering controls last night and they're working well now too! Only trouble I'm having is refitting them, what a chew on, the horn is just in the way!
    Just got my roof console, passenger door switch, speedo and safeguard switch left to do
  1. Dash conversion
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2012, 21:21
  2. Dash conversion
    By irmscher72 in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2011, 21:03
  3. LED Dash Conversion
    By kns in forum Bodywork & Interior
    Last Post: 7th March 2011, 23:09
