Results 1 to 10 of 15
Thread: front strut top bearings, question??
    oooooop north
    confused front strut top bearings, question??
    My strut top bearings are shot, REALLY shot!
    anyhow, the local motorfactors all want me to pay £60+ for a "bearing kit" apparently these contain the whole strut top mount ETC I need 2 (£120+) this seems a little steep to me!
    anyhow, there are SEVERAL sellers on ebay that are selling just the bearing for around £18 (so for 2 £36) A HUGE saving, im sure will agree! anyhow, the mechanic i use for big jobs says that just the bearing wont work as the rubbers ETC will be shot too, a cursory google says he is wrong! the rubbers and mount are usually fine, and just get the bearing off the bay!
    SOOOOOOOO thoughts please chaps! will I be ok with just a bearing, or will it need the whole mount, rubbers, bolts and bearing you get in the kit??
    cheers chaps, from 1 confused bungle!
    B..
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    Just done a bearings ....all good now.
    Engine : 1.9 CDTi
    Same here.
    OE quality ones from AutoVaux were about £35 delivered for the pair.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    dont buy cheap from the bay fella as you will have to spend out again when these cheap kits wear out very quickly
    oooooop north
    they aint cheap ones matey, there febi bilstein ones!
    I just really dont see the point in doing the whole mount, when a bearing will suffice!
    B..
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    sorry to hijack, but what are symptoms of worn strut top bearings? Do you have to dismantle strut to replace them or just remove it from car. I have spring compressors if need be.
    I have been having a particular problem with front, tramlining at low speed over rough ground and body roll side to side, wiggles under braking sometimes too. I have done arb bushes and drop links. I had thought shocks but the ride is generally ok, no bouncing, only at low speed under certain conditions. It stays quite flat round corners. I had thought track rod ends but there is no play at 9+3. Its doing my head in cos its like there is a specific thing wrong but I cant figure out what it is, and I don't want to start replacing suspension components willy nilly. It will need new front tyres soon. Is it worth swapping front and rear tyres seeing if this helps?
    oooooop north
    I suppose they could cause tramlining ETC, but the one thing thats gives it away as the top strut bearing is the CONSTANT crick crunch crunch crick grind ever time you move the steering wheel!
    HTH
    B..
    Engine : 1.9 CDTi
    Mine made a 'pinging' noise like the spring wasnt turning smooth.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    just get the bearing and yes you do have to dismantle the struts no matter if you buy the top mount or just the bearing , they arent that much dearer in the dealers
    the dearest part will be the labour if you're not doing it yourself
    london
    if there is a german swedish french outlet near you- then go there- they do the exact same parts for about 17quid inc vat. just say they're for a saab 93 and the year of your car and you'll be right ;-)
  1. Front shock/strut question?
    By Richard.roberts in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2012, 14:32
  2. used front strut bearings
    By paul.sessions in forum Parts for sale
    Last Post: 14th January 2011, 18:40
  3. Bearings on front strut
    By LITTLEBOYRED in forum Suspension, Wheels & Brakes
    Last Post: 6th February 2009, 23:47
Vectra c top strut mounts
vectra c top mount bearing
vectra c sri front strut
good strout mount vectra c
vectra c front strut
vectra c Front Top Suspension Mount & Bearing KIT
remove strut vauxhall vectra c
vauxhall vectra 2.0 d strut top mount
vectra c bearings
how to test strut bearing
vectra c front shock mount
if vectra c top strut mounts are rusted is it mot failure
vectra c strut top mount
