Thread: Vectra C - Rear Springs
    Regular Member 798EAT's Avatar
    Jun 2011
    Shropshire
    Default Vectra C - Rear Springs
    Hi,
    I am new on here and own a 1.9CDTi which I am ver happy with.
    I am currently on my second set of coil springs on the rear due to me carrying a fair bit of weight about in the back.
    Can I get some uprated springs for the rear that increases the ride height slightly so that it is not obvious I have a boot full?
    What springs do the police use on their cars, cos they carry loads of weight but cars never look low at rear.
    Cheers for your help guys.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Most people have changed their coil springs to Eibach springs. They lower the car 30mm or 15 mm if you have an sri model.
    They are much stiffer than standard vx springs also.
    To stop the rear end drooping down you can buy some rubber inserts from Halfords that you place in between the coils of the spring. I have used these when towing my caravan and work well.
    http://www.halfords.com/webapp/wcs/s...d=-1&x=25&y=10
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to correct section
    Irmscher Insignia CDTI 130
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You may want to look into the self levelling shocks that can bought from VX. They aren't cheap though
    london
    Quote Originally Posted by Graham View Post
    restricting a single coil on the spring from moving will put undue stress on the rest of it so making it more likely to snap. its a bit like cutting a bit of the spring off in your shed to lower and stiffen the suspension.
    also may invalidate your insurance as it is a mod- and a bit heath robinson at that. speak to vx and lesjofors if vx aren't very helpfull. or try replacing them with the vxr rear springs- from lesjofors- as they're a bit more rigid me thinks.
    Jul 2011
    ISLE OF MAN
    Quote Originally Posted by 798EAT View Post
    Hi,
    To help you KYB have a pdf file see webpage http://www.kyb-europe.com/pdf/KYB-Coil-Springs-2011.pdf PAGE 205 gives the info on Vauxhall Vectra C Estate springs they have "heavy duty" springs available they say
    West
    you can also buy heavy duty springs for the rear, as used by the emergency services & quite a few folk who do a lot of towing
    lincolnshire
    put estate springs on it , they take the weight ! lol
  1. 2 Broken Rear Springs VECTRA SRI 1.9CDTI 2006
    By mani911gt3 in forum Suspension, Wheels & Brakes
    Last Post: 8th August 2012, 09:53
  2. Rear Springs
    By bobmcn in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2012, 20:43
  3. Vectra SRi Hatch rear springs
    By leeds vectra in forum Parts for sale
    Last Post: 16th January 2010, 17:27
  4. sri rear springs
    By 30ltr nutter in forum Parts for sale
    Last Post: 22nd March 2009, 23:45
  5. Rear springs
    By bertbuckie1 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2009, 17:26
coil springs for vectra c estate 2008
vectra-c.com changing rear springs
vectra c estate rear springs
heavy duty rear coil springs vauxhall vectra 2007
vectra spring rx02
how many hours to change rear springs on a vectra estate
coil spring vectra c sri
meriva rear towing coil spring
vectra c estate helper springs
vectra c sri estate rear spring
2007 vectra1.9cdti estate heavier springs
irmscher spring opel vectra c
correct portion of rear coil springs on a vectra c
vectra c sri spring heave duty
heavy duty springs for vectra
xvids grannies
vectra c rear spring change
does vectra gts springs fit estate
vectra 07 diesel how to fit spring to rear of vehicle
is vectra rear springs different in height
replace vectra c rear springs
vectra c heavy duty rear springs
vectra c estate rear suspension
rear springs for Vectra 1.9CDTI estate
what are best replacement springs for vectra c 1.9 cdti site:www.vectra-c.com
