Results 1 to 10 of 15
Thread: broken egr pipe and blanking it off
    Regular Member coooky's Avatar
    May 2011
    washington
    Default broken egr pipe and blanking it off
    the egr pipe on my car has snapped in half and i have read about blanking it off
    now im not great with cars so here goes
    the car is a cdti 150 so when im looking down into the engine and see the egr pipe is the end what is in view that has a rippled part,the part where the egr is and is that where i place the blanking plate
    also with the pipe snapped can i just remove the part i can get to that has 2 allen bolts ?? also will i need the plate with the 9mm hole in it ??
    cheers and if that lot makes no sense i will get a pic when the rain stops
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I think a pic would help, to show where the pipe has actually broken.
    May 2011
    washington
    where the pipe is broken you cant see it only feel it
    what parts do i need to blank it off 2 these
    http://cgi.ebay.co.uk/EGR-Blanking-P...item35b2b52124
    and what else ??
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by coooky View Post
    and what else ??
    If the exhaust feed pipe is broken before the EGR, then you will need to sort this out ontop of blanking the EGR.
    As for blanking, one of those gaskets is enough, you slip it in between the bottom of the EGR (150) and the exhaust feed pipe (undo the two 13mm bolts, slip it in, refit bolts) - that's it.
    May 2011
    washington
    ok i need to get the cooler pipe fitted first
    Lancashire
    Trim : XP1
    Mileage : 66000
    They are only about £30 on eBay....
    http://cgi.ebay.co.uk/2009-VAUXHALL-...d=236954423576
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to correct section
    Irmscher Insignia CDTI 130
    May 2011
    washington
    [QUOTE=Dan_BlackSRi;1552709]They are only about £30 on eBay....
    http://cgi.ebay.co.uk/2009-VAUXHALL-...d=236954423576[/QUOTE
    see the end where it tapers on the right its the part that clamps onto that and then allen bolts onto the manifold thats snapped where it clamps on
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Wherever it has snapped, you'll have to replace it or you'll be leaking exhaust gasses into your engine bay. Most people blank the EGR either between EGR valve and inlet manifold, or between EGR valve and cooler pipe.
    May 2011
    washington
    yep trying to get hold of a used part before i have to pull out the £100
  1. EGR Blanking
    By awsri4 in forum Diesel Engine related
    Last Post: 16th July 2014, 09:22
  2. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  3. blanking egr
    By littlegreenmartian in forum Engine & Drivetrain
    Last Post: 28th May 2012, 06:16
  4. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  5. Exhaust-Flexi-Pipe Broken
    By Dreamyhose in forum Engine & Drivetrain
    Last Post: 16th October 2008, 09:27
vectra b egr pipe broken
