Thread: lambda changed but more fault codes.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default lambda changed but more fault codes.
    hi all, changed the faulty lambda on the inlaws vec 1.8 non vvt but got a few extra fault codes now showing.
    0141
    0036
    0170
    both lambdas have now been changed, along with the crank sensor and air flow meter. and still running like a bag of bolts! any ideas? cheers Tim
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    0036 pertains to the second lambda, wonder why a new ones not cured that code? you tried resetting codes by disconnecting the battery? I take EML is still on?
    Nov 2010
    BRECHIN
    battery is off just now, but no the eml aint on, witch i found strange. not sure if this is anything to do with it but you get popping thru the exhauast while on idle? but sounds fine when reving. he had the timing belt changed a while back and it all started from then.
    feel real bad for him, costing him a fortune but its still running gash. must admit tho it is better after the second lambda was changed. it not cutting out anymore.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Take it you've double checked the timing?
    Nov 2010
    BRECHIN
    no, can this be done? with out ripping the engine apart?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Cant remember mate. Check this thread though, sound similar?
    http://www.vectra-c.com/forum/showthread.php?t=139151
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Heres the how2 on how to do the belt on z18xe, should help you out bud.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Quote Originally Posted by TimTay View Post
    0141
    0036
    0170
    what checks were made to make you decide to fit a o2 sensor ?..was it just fit it and see or did you do any checks / live data readings ? .....ok 02 sensors can go faulty but as a rule they normally show another fault ie both sensors showing faulty maybe due to a missfire / poor running given this will throw them out of kilter .... checks need to be made to be shure it was the sensors ,to me it dont sound like its them it has another fault that needs fixing .....
    Nov 2010
    BRECHIN
    im not a lets change this see what happens guy, crank sensor was changed thru advise on the forum, and i did live data reading via opcom to see that the post cat lambda sensor was faulty and not registering any change at all in the mv. also the dtc's said that it was faulty. so thought it a good idea to go ahead and change it. and it did make a massive improvement on the running of the car, no more cutting out. but as i said something is not right,
    as dasarab posted up an almost exact situation on running in another thread and as the cambelt was changed and has been hellish since im assuming that it is going to be timing related. it was a homer from a guy at his work think this is going to be the root of the issue i think, but looking thru the how2 im not going to atempt it myself. dont want to make it worse lol
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sounds like the timing could be out ,
    have you checked the timing marks?
  1. fault codes eml
    By richy1974 in forum Engine & Drivetrain
    Last Post: 21st July 2012, 13:23
  2. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  3. fault codes
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2011, 10:20
  4. 2.0 dti fault codes help
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 19th May 2009, 20:33
  5. Lambda fault codes
    By Ian T in forum Engine & Drivetrain
    Last Post: 3rd July 2008, 20:59
