Thread: which headlight bulbs ?????
    wolverhampton
    Default which headlight bulbs ?????
    i know this has proberly been asked many times but whats the best and brightest bulbs to buy for a signum as the standard ones dont light the road up very well....
    Regular Member farley2708's Avatar
    antrim n.ireland
    Hi mate,went down the same route as you,changed bulbs.made NO difference at all,apart from my wallet,HID is the best by far,mine are 4300k from a member on here,£50-£60 will leave you with plenty of light,then follow 'duncans' thread on adjusting the headlight,other replys you'll get will prob say sumfin the same HIDs
    scottish region
    hids 6000k or 8000k cant go wrong
    Regular Member Ben_'s Avatar
    Audiville, WM
    I found osram nightbreakers to be good mate but as others HID will beat any uprated bulb, just depends on what your budget is mate.
    11 Post(s)
    Quote Originally Posted by Ben_ View Post
    I found osram nightbreakers to be good mate .
    Mine lasted approx 8 months. That's the trouble with bulbs which claim to be brighter. They're worked harder to get the extra performance out of them and their lifespan is shortened because of it.
    HIDs is the way to go.
    wolverhampton
    thanks guys i have seen something about canbus being affected i have no idea what it is if hids are the way to go then where can i get some fitted and how much..
    Audiville, WM
    Mine have last 18mths mate and all good......so far! Will be getting HiDs after the summer tho
    scottish region
    just buy cancelers and the canbus is not affected mate
    Engine : 1.9 CDTi
    Post in your local area and see if anyone would fit them for you.
    If you were local I could have done them for you.
    11 Post(s)
    Quote Originally Posted by vectrac150cdti View Post
    Od fit a dedicated kit that is designed to work on cars that have canbus networks.
    eg, THESE
    I fitted these back in Sep 2009. No bulb failure errors from the cars check system (yet).
    Last edited by Big Dave; 11th June 2011 at 21:03. Reason: Amended month from Aug to Sep
  1. Headlight Bulbs
    By Tam80 in forum Styling
    Last Post: 26th September 2010, 13:28
  2. New headlight bulbs
    By ROB WOODHOUSE in forum Styling
    Last Post: 27th February 2010, 21:07
  3. Headlight bulbs???
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2008, 13:08
  4. Headlight bulbs again (sorry)
    By Ian T in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2007, 12:58
  5. Headlight Bulbs
    By LEW1S2006 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2007, 00:07
