Results 1 to 10 of 15
Thread: throttle problem
    Full Member stuart bigboy's Avatar
    May 2007
    kent
    Default throttle problem
    my wife has a 1.7 cdti astra h a couple of weeks driving along the motorway i lost all throttle was pressing it but nothing was there it stayed on tick over at 14oo rpm had the rac out and found fault codes saying throttle position sensor 1 and 2 fault took it to the garage they cleared the fault and said there was nothing wrong with it . it has now done the same thing again has any one got any ideas
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Throttle position sensor has went open circuit imo This is more like to be in the Throttle body. My 1.9CDTI done the same, spanner light, nothing from the throttle pedal but the engine sat at 1,500rpm.
    Gazza4
    May 2007
    kent
    Default throttle
    thats excactly what happened to mine was the part exspensive
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    i had this happen to me - turned the engine off and and turned it back on again and it worked fine.......I did have the codes read and it chucked up the throttle position sensor code twice - two different ones.....
    so how do you rectify this issue?
    thanks,
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by stuart bigboy View Post
    well for the 1.9 I removed the throttle plate and problem disappeared. I have now soldered the broken joints but not replaced the plate. No issues anyway. Get any possible fault codes read. There should be some stored.
    Mar 2011
    M4 Junc 12
    mines the 2.0dti......not sure how to fix the problems....
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by wingz123 View Post
    Think yours is vacuum operated but not sure.
    Mar 2011
    M4 Junc 12
    yeah you could be right actually there mate so guessing its leaking somewhere?
    Sorry didn't mean to hi-jack the thread.....just never seem to get any responses when i post up!
    May 2007
    kent
    Default throttle
    iv been told its the pedle and the bit on the throttle body not sure what bit to change
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    They told me the pedal but it was the throttle body that was faulty on mine. Try and get a second opinion, if it was a 1.9 you had I would sya TB but as it's a 1.7 I can only say by the symptoms you're describing it's the TB.
  1. 2.0 dti throttle postion sensor problem
    By frankiebdv in forum Engine & Drivetrain
    Last Post: 25th March 2012, 14:15
  2. Signum throttle 'pulsing' problem
    By DHobbs in forum Engine & Drivetrain
    Last Post: 28th November 2010, 14:01
  3. Throttle...
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 27th July 2010, 22:50
  4. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
  5. throttle problem with a vectra B 2.0 16v
    By bappy in forum Engine & Drivetrain
    Last Post: 21st August 2009, 14:19
