Results 1 to 10 of 13
Thread: Gearbox oil change.... Too much came out!!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Default Gearbox oil change.... Too much came out!!
    Hi guys finally got round to changing my gearbox oil I've been waiting for the drain plug.
    Anyway got the oil out all be it after a bit of hassle off the drain plug.
    But what my question is. Is I've filled it back up with the 2.2 litres as stated on auto data.
    But I've noticed that over 3 litres has came out? :-S
    So should I put more oil in or is the amount I put in correct?
    Car is 54 plate v6 cdti manual gearbox
    Regular Member matt.d's Avatar
    May 2011
    gravesend
    Vehicle : vectra c
    Trim : breeze
    Engine : 1.8 16v petrol
    was the oil hot when it came out and was it the original gear oil
    Glasgow
    If its the 6 speed F40 then that would be correct, the recomended amount of oil was changed to ease on difficult gear changes from 1st to 2nd when cold i believe.
    For some reason i think its 2.4L thats should go back in but i could be wrong.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    I put put 2.4 in just to give it that bit extra but should I put more in an make 3litres the same as came out??
    I've took car for a drive and it feels ok.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    2.4L for the F40 mate
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Celes View Post
    Spot on so should I leave the 2.4 or put the 3l in that came out?
    Jun 2011
    lincolnshire
    Default hi
    Hi am new to this site. i have changed almost everything now on my vectra but i am after changing the gearbox oil this weekend but i am not a 100% sure how much to put in it when i empty it i have got the oil got 3L. it is a 05 1.9cdti 120. can someone help me with how much to back in gears not to smooth 1st 2nd
    thanks for your help
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Quote Originally Posted by spooky100001 View Post
    You need to check if you have a M32 or a F40. f M32 its should be 2,4 liter.
    Aug 2010
    North of Norway
    http://www.opel-infos.de/getriebe/f40.html
    F40 should have 3,2 liter. But some people said opel/vauxhall has change to 2,2 to get it easy to shift.
    Aug 2010
    North of Norway
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. M32 gearbox oil change??
    By shb1988 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 20:51
  3. F23 gearbox and oil change?
    By Deadman in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:16
to much oil m32 gearbox
