Results 1 to 10 of 19
Thread: Help : af40 stripped fill bolt
    spain
    Default Help : af40 stripped fill bolt
    Hi,
    during the automatic gearbox oil change procedure, using a torx key, I messed up the fill bolt stripping it ( clearly the factory default torque was so different from the 55 Nm reported by the repair manual ). Now i'm wondering how to remove it. Anybody has any idea?
    Here's a pic of this bast..d ( before the mess... ).
    Thank folks.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    if its a t45 use a t50 and hammer it in there try that failing that hammer it off
    Mileage : 000
    Quote Originally Posted by bangty 1 View Post
    Ne has stripped the thread. Not knackered the Torx head up.
    Mileage : 000
    Could you get someone to try and lever the head up either side with two small screwdrivers, whilst you turn the Torx head, it might just be enough to catch the thread and unwind it.(with a bit of luck).
    Sep 2010
    in a box
    well he asking how to remove it so im lost now to remove it do as iv sed but if you read it he asks how to remove it
    Sodding Typical on Sea
    I think we need some more info is it threaded, or did the torx head get mangled?
    Glasgow
    From reading i take it he has rounded it. Hammer and a chisel to catch the edge of it should'nt take much to loosen it. Then replace it with a brand new one and dont over do it lol.
    spain
    Quote Originally Posted by Derek Mc View Post
    The torx head get mangled...
    I'll post a picture of the mess asap.
    thanx
    That is what I had suspected and byebyeitsagsi has hit the bolt on the head,,,,,,,,,,
    Sep 2010
    in a box
    see i was right he ****ed the head not the thread so bigger torx bit or hammer and chisel it out
  1. Egr bolt thread stripped?
    By felixx in forum Engine & Drivetrain
    Last Post: 28th July 2015, 20:39
  2. Today I stripped....
    By wingz123 in forum General Chat
    Last Post: 26th April 2011, 11:11
  3. Af40 auto box drain and fill plug locations
    By Dougb in forum Engine & Drivetrain
    Last Post: 29th September 2010, 20:29
  4. My stripped out clio 172
    By W17GLE in forum Motorsport / Formula 1 etc. chat
    Last Post: 4th December 2009, 22:11
  5. Stripped!
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2008, 09:10
