Thread: Really stuck! Tensioner not tight....help!
    aberdeenshire
    Default Really stuck! Tensioner not tight....help!
    Afternoon folk, i'm in the middle of changing the cambelt on my vectra 1.9 cdti (150) and when i set the tensioner with the arrow lug to the hole and tighten the bolt that goes through it just keeps backing off and slacking the belt??????
    No matter how tight i get the bolt going though the tensioner, it just releases the tension!
    I've done a few timing belts in the past and set tensioners etc but this one has me totally stumped!
    Please help
    aberdeenshire
    Where should the arrow sit?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I do them from underneath, put pressure on it & the arrow will flick upwards, hold level with hole then tighten, the arrow should hold in its position if not you have a problem somewhere ?. IF THE BELTS SLACK TRY THIS? there should be 43 teeth from the bottom (last belt tooth) from the underside of the cam sprocket going downwards to the right, to the first belt tooth making contact with the crank (this side of the belt ( the RIGHT HAND SIDE) must be tight!! before setting up the rest of the belt, this is the easiest way of getting it tight & right.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by the-wizard View Post
    Forgot to say put it on the cam first (hold in position) then on the crank (hold in position)only, then slip over idle roller, this will be tight but its achievable, the above 43 teeth will give correct tension on the RH side, the rest is fit loose then tension! as above.
  1. How tight are you?
    By signum_rob in forum General Chat
    Last Post: 14th May 2012, 21:48
  2. Why is Vx so tight?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 03:37
  3. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  4. Replies: 15
    Last Post: 2nd August 2009, 00:11
  5. hee hee im a tight wad!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2006, 21:57
