Results 1 to 10 of 11
Thread: Sorry folks but another air con question!
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Default Sorry folks but another air con question!
    Hi all when I switch the air con on I can't hear the pump working and the engine revs stay the same as well as it blowing out luke warm air. Does this normally mean that there is a leak or could it just need a regas? I don't want to go and pay for a regas for it to be empty ten mins later.
    Thanks again for your advice Gaz
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to correct section
    Irmscher Insignia CDTI 130
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Sorry
    If the system is empty then the pump will not operate (low pressure)
    Therefore a pressure test is required, the system is then regassed and rechecked for leaks
    Find a specialist that does not charge for the regas after the leaks have been repaired
    Equally, the gas often leaks away after 5 years and simply needs to be replaced, typically the condensor has breached
    Check the condensor for dark patches
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    does anyone have any pictures available to show where the air con components live??
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Thanks m8internet hopefully the last option applies.
    11 Post(s)
    Quote Originally Posted by gaz1965 View Post
    kwikfit won't charge you a penny if the system has a leak.
    Quote Originally Posted by nikroc View Post
    No need for pictures
    Stand at the front of the car with the bonnet up
    The large silver radiator nearest the bumper is the condensor
    Follow the silver pipes to the offside of the car
    They may disappear into the side of the engine, that will be the air con pump
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Had it topped up today and no leeks so it's nice and cool inside again now :-)
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Kwik Fit have done mine twice, and said no leaks.
    It lasted one month the first time.
    This time, It's been 3 months, but it's not as cold now, as it was 3 months ago, although the pump still kicks in, can see it cutting off in the next week or so
    Off to see a proper air con specialist next week
  1. Hey folks
    By GreatScot in forum Introduce yourself.
    Last Post: 2nd November 2010, 20:01
  2. Quick question folks?
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 19:50
  3. hi folks
    By andyish in forum Introduce yourself.
    Last Post: 24th January 2009, 18:31
  4. Hi Folks!
    By DoncasterGSI in forum Introduce yourself.
    Last Post: 22nd July 2007, 13:22
  5. Replies: 14
    Last Post: 19th April 2006, 23:40
