Results 1 to 3 of 3
Thread: Which fuse is ignition live? Got some DRL's coming!
    Apr 2011
    Cornwall
    Default Which fuse is ignition live? Got some DRL's coming!
    Hi, I've just bought some DRL's for my Siggy and was wondering which fuse to piggyback off so they come on whenever the ignition is turned on? Also is it just as simple as wiring the negative to the fuse and the positive to the battery live terminal? Not too great with electrics!!!
    Regular Member hagga's Avatar
    kingswinford
    Quote Originally Posted by shane5861 View Post
    no and no....
    Think i'd be easier to see what unused fuses become live when ign switched on and use one of those... saying that if you know nowt about electrics I'd find some to do it for you... last thing you want is to do something wrong and set a loom on fire.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Go to the engine compartment fuse box as there are several unused outputs in there. Connect a multimeter (set to volts) find a dead output, switch on ignition and see if you have power, if not try another position.
  1. Quick How2 on fitting Ignition live DRL's
    By shane5861 in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2012, 16:54
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  4. ignition live
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2011, 23:45
  5. Ignition positive on boot fuse box
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2009, 22:44
