Thread: sump plug
    Regular Member boodoo warrior's Avatar
    May 2011
    derby
    Default sump plug
    could any 1 help me im doin a oil change today on my face-lift vectra 2.2 sri and was wonderin if the sump plug is hex head or torx and what size. thanks
    Regular Member Keif's Avatar
    In the Garage
    It will be a Torx, can't remember what size tho (T25 rings a bell).
    Sep 2009
    Audley STAFFS
    it is a TORX, Make sure you clean the hole out where the bit goes in, (I use WD40) USE A STRONT BIT, I use Halford professional bits, the bit goes in quite a long way make sure its in all the way lots of people have had problems because they F/U the sump plug ,also it is best to change the sump plug sealing ring, an oil change kit from a VX Dealer oil/filter/ seal, is cheaper than just buying the oil.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i replaced mine for proper ones that you can put a proper socket on,
    Regular Member Jezzy's Avatar
    S.E
    You get both types - torx and hex, basically whatever GM had lying on the shelf the day the car was made.
  1. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. Sump plug
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 8th May 2012, 20:46
  4. sump plug on my 2.2 sxi
    By smilerwas in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 22:53
  5. Sump Plug Nut
    By si_hoss in forum Engine & Drivetrain
    Last Post: 22nd February 2010, 18:32
vectra c using hex sump plug
