Thread: Rattle from back brakes
    Ashburton
    Default Rattle from back brakes
    I have a 2003 sedan and there is a rattle coming from the back brakes ,it stops when you put the brakes on or pull hand brake on ,sounds like loss pads ,has anyone had a problem with this and is there a fix .
    Jan 2006
    Skynet HQ EMEC#5
    Turn the radio up??
    Check the friction material is still bonded to the pads steel backer, not unknown for the 'glue' to fail..that will make then rattle.
    also check the caliper mounts for the correct torques..
    Ashburton
    Hi .I have had the linings checked and they where put in new when i go the car 4000km ago and were still like new ,they replaced them with an other brand and shimed them ,they are better but still rattle at slow speed around town ,or thats when you can here it .
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    get some genuine pads,they are held to the pison by a clip
    so are the aftermarket one's solo..
    fitted a set of Bosch pads to the rear of mrs GSi's vec and they were identical.. apart from the price!!!
    a bit more planning and i could have got the pad/disc kit for less
  1. Rattle from back of engine?
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 4th September 2012, 21:51
  2. Am back about my brakes
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 7th June 2012, 01:30
  3. Am back about my brakes
    Last Post: 6th June 2012, 01:15
  4. chain rattle back
    By bundy b in forum Engine & Drivetrain
    Last Post: 18th May 2009, 17:41
  5. Rattle from brakes?
    By wee-del in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2007, 21:44
