Thread: car rattling, cannot find source
    Jun 2011
    Glasgow
    Default car rattling, cannot find source
    have changed 1 busted front coil spring and 1 busted rear trailing arm bush, and the car rattle really badly
    its like a metalic chatter rattly type of noise, like a loose heat shield or an exhaust clamp thats loose, something metalic
    i don't know what else it could be, its driving me mad
    however if i use the handbrake up a few clicks it goes away if i drive it, or if i tap the brakes there and i move it forwards over bumps or small dents in the road the rattle stops
    ive tried with a screwdriver to try and play the pads up n down but there is no movement, so i don't know what the heck is going on?
    also it feels like sometimes the sound is coming from the centre of the car going backwords, its hard to tell
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Rear pads rattling in the caliper/s. Quite often happens when replacing with after market pads. I had to make small shims(out of copper) to cure the rattle, did the job for me.
    West Sussex
    Quote Originally Posted by mox123 View Post
    I've had exactly the same noises for ages, just as you describe. I've always assumed it's something loose in the exhaust system. Let me know if you find out what it is because I can't!
    Jun 2011
    Glasgow
    well i will find out in a few days when i take everything off and have a good inspection,
    do me a favor, can you open the rear passenger door whichever the side the noise comes from, and really violently bounce the car up and down to see if you hear any sort of metalic squeeks or something rubbing of something, also try pushing it sideways from the body and forwards and back from the inner door edges,
    as thats what i get,
    West Sussex
    I'm guessing mine could be a different issue. I hear the rattle when the car is idling and even louder when I put it in drive. It's not worse over bumps, but it always sounds as if something is about to fall off but so far hasn't. I would say though that the noise seems to come from the area from the centre to the rear passenger side.
    Glasgow
    Have you guys checked that the heat shield above the exhaust and around the spare wheel well is all secure. They have a habit of corroding and causing rattling.
    Regular Member BoroDave74's Avatar
    Attleborough
    I had a sound like that right after they resurfaced our road, I kept getting under the car to look, but couldn't see anything. A very large bit of gravel had got caught up in the osf pad and disc. Kind boys at ATS removed it for me.
    Jun 2011
    Glasgow
    i figured it out, brake pad was loose rear pad, so i swapped them around and noise is all but gone
    this was driving me mad for months,
    finally got my arse out and sorted it out
  1. Any1 know where to source the plugs?
    By yysnet in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 14:32
  2. Where might I source a facelift airbag from?
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2010, 20:13
  3. Recommended source for new alloy?
    By CodeV in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2010, 15:23
  4. Source Another CCR 2006 or Go Aftermarket
    By Hedgehog70 in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2009, 21:38
  5. Counter strike source.
    By thetic in forum Games Room
    Last Post: 1st January 2009, 19:45
