Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Vectra C 1.8 SRI (faults?)
    May 2011
    STAFFS, UK
    Default Vectra C 1.8 SRI (faults?)
    Hi ive recently purchased a vectra c 1.8 sri 2003,
    I find its a very nice car but have a few faults.
    1 is that i find it terrible on fuel, on a run the most i can get is 27mpg.
    i find it very expensive to run and dont think this is right, engine has 114k on the clock with full serviec history and cambelt change at 112k by pervious owner, engine is quiet no knocking or tapping.
    I dont have any engine managment light on but really think there is something wrong!.
    the car seems to have no guts at all if im honest and do have a slight rabbit on driving of in 1st sometimes. apart from that it feels pretty smooth.
    Can anybody shine some light on this please?
    thanks tony
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Someone else had this issue not long ago, don't think we ever got to the bottom of it. At the moment combined im getting 38mpg, on a run well over 40 mpg. Might be worth checking the condition of the plugs, air filter, fuel filter as a full service history does not mean its actually been serviced.
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    How long is it since last service? Sparks, oil etc.
    Full Member Big Sig's Avatar
    What sort of journeys are you doing for that mpg? short trips or long ones? Don't forget its a fairly small engine and a pretty heavy car.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Is the thermostat ok, I'm sure I read on here if the stats knackered it will drink juice
    Northampton
    Engine : A20DTH
    Mileage : 88000
    for comparison I was getting 420-450 out of a tank but that included a lot of motorway miles. Also I drove it quite hard but used the cruise control were I could.
    The main fault you get is failed thermostats, once warm the engine should stay at 85-90 ish and not drop regardless of conditions. Mine was faulty and would drop as I drove and would hardly move in the winter. I never did get round to changing it so I cannot tell you if it would have improved my mpg.
    I also believe there was clutch issue with the 1.8 which was subject to a recall if I remember or it was a known fault and had a remedy, one or the other.
    To be honest the 1.8 engine should never have been fitted to the Vectra C as the car is too heavy. The 1.8 is ideal in an Astra MK4 where it preforms well (we have one sitting on the drive). The newer 1.8 VVTi is a better engine (140bhp compared to the 122bhp of your engine) but is still a bit under powered for the size of car
    Mar 2011
    llandrindod wells
    Also if it hasn't been done, do the airbox mod, I found it improved mine no end
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by triple595 View Post
    I fitted the K & N Cone Filter to mine along with a twin exit exhaust
    May 2011
    STAFFS, UK
    Ive done a few trips (60mile) and also i do alot of short (10mile) trips. both average at 26-28.
    as far as i no was serviced last year in july 4k ago of which states its had brake fluid,spark plugs,fuel filter,pollen filter,along with cambelt.
    ive checked the air filter and that looks new, oil looks ok. not checked the plugs. but must say the pollen filter is very dirty (maybe they ticked its changed but hasnt).
    the car temp guage is abit strange at times as it at times it just shows nothing "needle hasnt moved".
    but if i start from cold and leave it running never goes over the 80-90 and fan kicks in so i wouldnt a clue if something wrong with thermstat??.
    as for the clutch i do seem to have a problem, clutch peddle feels weird and i can hear noise when engaging the clutch from the pedal, to me the pedal doesnt return fast enough or maybe sticking, but clutch is biting ok and biting point seems ok.
    I do have problems with my brakes, they squeak all the time and it drives me crazy, i had them checked and they said the pads need copper grease so they greased them up (local garage) and they never made a noise for about 5 mile and now the noise bk again.
    maybe the last owner had a problem with the squeaky brakes hence the brake fluid on the last service, "maybe they didnt do it right".
    there my current problems with my car, apart from that its a nice car although i did have to change the suspension springs a day after i purchased this car due to the rear was snapped, but after putting on a set of lowering springs as a replacment car looks rather nice.
    i really hope i can get tot he bottom of these problems and mainly the MPG as its costing me a fortune. trip stats say 210 miles for 10 gallons its used, that is from a mixture of long and short jurneys.
    any help for these problems will be help full.
    Sep 2009
    Audley STAFFS
    after you have done a longish journey check all the disc's to see if one is getting hot/binding. check the plugs for your self, I found BOSCH Super work well in my none vvt 1.8. as for mpg,, do your own check,ie fill car right up, set trip to zero do say 300 miles of your normal driving, check miles, devide ltrs by 4.546 to give galls used. my car has averaged 38 mpg but does not do city/ rush hour traffic, ONCE I had a week of city/town driving it did 32 mpg so you are not that far off.
  1. [Vectra C] [02-08] 03 sri water in foot well but now have many electrical faults
    By gavin1981 in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2012, 21:51
  2. Vectra C 1.8 2002 CIM and ECU Faults
    By Dougie in forum Troubleshooting
    Last Post: 19th December 2011, 13:41
  3. Im going to view a Vectra 2.2 SRI! any major faults to look for?
    By David P in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 19:10
  4. loads of faults on my vectra - HELP
    By molloy in forum Engine & Drivetrain
    Last Post: 23rd January 2011, 20:44
  5. vectra- problems or common faults?
    By fergusix in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2008, 16:48
vectra c engine 1.8 faults
