Thread: Corsa B help
    Edinburgh
    Default Corsa B help
    My wife has an x-reg Corsa B 1.7DTi. When she turns the steeringwheel to the right and the car is in motion there's a sort of grinding/vibration noise which to me appears to come from the passenger side wheel arch. When the steering wheel is turned to the left, there is no noise.
    Any ideas what might be causing it?
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Would the drive shaft be coming loose?
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    I've had a drive shaft go bang on a roundabout in Dundee few years back in the wifes old corsa. Got underneath to have alook pulled the loose gaitor away and piles of ball bearings fell on the deck!
    Edinburgh
    I would have thought if it was the driveshaft it would have made a noise in a straight line too? Perhaps the bearing then?
    Edinburgh
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    think you need to get it up in the air with the wheel off and look for any wear marks if none keep on axle stand and get some one to start car and engage gear and slowly release the clutch and listen and turn wheel till it makes the noise
    but be careful with loose clothing and hands
    Regular Member Jezzy's Avatar
    S.E
    Have you checked the springs out?
    Regular Member Keif's Avatar
    In the Garage
    Had the same thing on my wifes Corsa C. (opposite side and direction of steering to yours)
    Once the wheel was off the clues were there. Grease all round the outer CV joint/rear of the hub. Once re-greased, the noise went away.
    That would be my first check
    Edinburgh
    Quote Originally Posted by Keif View Post
    We have a winner! ^ See pic below.
    Does anyone have experience of the "univeral stretchy CV boots"? Am I better going for the real deal instead? If so, how easy is it to remove CV joint from a driveshaft?
    In the Garage
    Stick with the real deal, the universal ones don't last anywhere near as long, so would be false economy.
  1. corsa vxr
    By ecotommy in forum The 'Off Topic' room
    Last Post: 22nd February 2011, 19:26
  2. Anyone know anything about Corsa 1.2`s?
    By PeterVV in forum General Chat
    Last Post: 30th January 2009, 21:53
  3. Corsa C Alloy And Corsa D Grille
    By andy.l in forum Parts for sale
    Last Post: 6th May 2007, 12:46
  4. Corsa VXR
    By Madgunner in forum General Chat
    Last Post: 16th March 2007, 00:56
