Hey guys. I've just received angel eyes 4 my birthday and can't wait to fit them!!! Is there a how2 or can any give me a step by step guide??
Cheers guys
Cheers guys
you may find this help full to you . after fitting them you may need to adjust the aim as sometimes they are a bit high ,there is also a how to do this . easy to do .
http://www.vectra-c.com/forum/showthread.php?t=15114
Pre Face's mate are easy also to fit OEM lights, the hardest part i found was putting the leveling motor back in , easiest way i found was to lift the light up so the glass is facing the sky, and then fit the motor, if you know what i mean
Cheers. Will keep u posted with how i get on!!
I found the best way to fit the motor is push down on the other side of the light housing to get the motor side to lift up........when looking at the light from behind the there 2 windows one where motor goes, one without push down the unit that doesn't house the motor, should make the job easier pal
HTH good luck
All fitted!! Two torx screws needed drilling out which was the hardest job! Thanks 4 the advice!!
