Thread: Fitting angel eyes
    Regular Member jake.clay's Avatar
    Mar 2011
    York
    Talking Fitting angel eyes
    Hey guys. I've just received angel eyes 4 my birthday and can't wait to fit them!!! Is there a how2 or can any give me a step by step guide??
    Cheers guys
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    you may find this help full to you . after fitting them you may need to adjust the aim as sometimes they are a bit high ,there is also a how to do this . easy to do .
    http://www.vectra-c.com/forum/showthread.php?t=15114
    the vectra has gone , but not far away so ill still see it form time to time
    Full Member spennny's Avatar
    Blantyre
    Pre Face's mate are easy also to fit OEM lights, the hardest part i found was putting the leveling motor back in , easiest way i found was to lift the light up so the glass is facing the sky, and then fit the motor, if you know what i mean
    Mar 2011
    York
    Cheers. Will keep u posted with how i get on!!
    Regular Member Ben_'s Avatar
    Audiville, WM
    Quote Originally Posted by spennny View Post
    I found the best way to fit the motor is push down on the other side of the light housing to get the motor side to lift up........when looking at the light from behind the there 2 windows one where motor goes, one without push down the unit that doesn't house the motor, should make the job easier pal
    HTH good luck
    Mar 2011
    York
    All fitted!! Two torx screws needed drilling out which was the hardest job! Thanks 4 the advice!!
  1. Replies: 21
    Last Post: 21st December 2012, 19:20
  2. Angel eyes.
    By badback in forum Styling
    Last Post: 22nd April 2011, 09:38
  3. Angel eyes pre-fitting
    By suj786 in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2010, 20:33
  4. Angel Eyes
    By Daywalker in forum Styling
    Last Post: 13th November 2009, 17:33
  5. angel eyes .......... help fitting
    By m8wos in forum Styling
    Last Post: 22nd October 2008, 20:01
