Thread: No power & very lumpy running 1.9 cdti
    Mar 2011
    OXFORDSHIRE
    Default No power & very lumpy running 1.9 cdti
    Hello to All
    I wonder if any one can help me
    My vectra 1.9 150 cdti has just tonight developed a concerning issue.
    symptoms are
    Hardly any power.
    Runs very lumpy as if it is on 3 cylinders.also at idle
    seems to run smooth on trailing throttle but as soon as you put your foot down the problem starts again.
    3rd injector wiring is brown with a white strip! i don't know if that good or bad.
    Spanner light is on all the time.
    No smoke....
    I hope that this is the 3rd injector wiring issue as atleast it will be cheap to repair...
    If not does anyone have any suggestions as to what it could be.
    Thanks & regards.
    Phil.
    London
    had a similar issue and after the booster valve clean it was better.
    Then I had the EGR changed and it was back to normal ...
    Booster valve is easy to do, so maybe start with that and see
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes its the 3rd injector issue, get the new wiring/plug from Vauxhall.
    I would not bother checking anything else until you sort the wiring/plug.
    If your 3rd injector plug is yellow then they need it done regardless if it fixes your current fault or not
    carlisle
    mine was exactly the same and was the third injector wiring, think the part was only just over a tenner, but I got charged a fortune in labour
    Regular Member sscully's Avatar
    Jul 2011
    WALLASEY
    Vehicle : Vectra C Facelift
    Trim : SRI
    Engine : 1.9 Diesel
    Mileage : 89000
    I have same issue what was the fix in the end.
  1. Replies: 30
    Last Post: 28th August 2012, 08:35
  2. running lumpy
    By bert01909 in forum Engine & Drivetrain
    Last Post: 9th January 2012, 15:10
  3. Running VERY lumpy 1.9 cdti 150
    By kevcdti in forum Engine & Drivetrain
    Last Post: 9th June 2011, 08:33
  4. cdti running really lumpy and no power??
    By richiem in forum Engine & Drivetrain
    Last Post: 7th July 2010, 19:16
  5. 1.9 CDTI Lumpy Running at Idle
    By Dazfoz in forum Engine & Drivetrain
    Last Post: 13th April 2009, 18:23
vectra c 1.9 cdti sri running lumpy
