Thread: coolant warning light
    Regular Member LarfinBoy's Avatar
    Bedfordshire
    Default coolant warning light
    once upon a time....
    -coolant warning light came on - so topped up expansion tank with 100ml
    -coolant light on again - but when opened cap depressurised to 1" over cold mark
    - radweld in and into local garage to pressure test - all ok
    - vxl service mgr reckoned might be sensor faulty
    - drive 10 miles warning light on. stop for fuel - coolant level down. continue 30 miles light off.
    - currently engine cold - but level under. uno cap - expands to over. drive 40 miles and goes under 1" and warning light on.
    So....doesnt seem to be loosing coolant - system seems to be getting pressurised??? and pushing level below???? ideas please
    Is it ok to just keep unscrewing cap to release pressure???
    Changing the car on 1st July so panicking if it will last
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Possibly just the thermostat or water pump needs replacing
    Keep a close eye on the temperature guage.
    Bedfordshire
    temperature gauge seems fine - sits at 85 and creeps to 87ish in traffic. Hasnt hit 90....yet
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by LarfinBoy View Post
    You'll find it can reach about 92ish in traffic for prolonged periods.
    My guess is the thermostat is sticking, or the water pump is worn
    A known issue on the 3.0 V6 CDTI
    Didn't you post a similar question a few weeks ago?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Air lock in the system?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Or get head checked I had similar symptoms to this an had headgasket failure
  1. V6 Coolant Warning Light
    By iani in forum Engine & Drivetrain
    Last Post: 30th May 2011, 14:12
  2. Coolant warning light
    By sproket in forum Vectra C / Signum Troubleshooting
    Last Post: 17th May 2010, 19:15
  3. Low coolant warning light -3.2 GSI
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2009, 09:33
  4. Coolant Warning Light
    By parapaul in forum Engine & Drivetrain
    Last Post: 4th October 2008, 18:25
  5. low coolant warning light
    By wxmlad in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2006, 06:29
vauxhall vectra coolant warning light
vectra c radiator warning light
vectra c coolant level sensor
vectra coolant level sensor
collant tank light on vectraopel vectra c 2008 radiator lightvauxhall vectra coolant sensorradiator warning light vauxhall vectraengine coolant light on vectra cVectra cdti coolant warning come a on when driven gardvectra c coolant warningReset coolant light on opel vectra c vectra c coolant warning lightvectra c radiator top up dashboard lightradiator light vectra zclow water level light vectra ccoolant warning vauxhall insigniacoolant warning light Vauxhall omegavectra c radiator lightlow coolant light vectra even sensor changed water level sensor on a vectravectra c orange coolant lighthow to change coolant level sensor on vectra cvectra c coolant levelvectra c how much coolant lass for ligjt
