Thread: can your swirl bar be fitted either way ?
    Jun 2011
    Liverpool
    Default can your swirl bar be fitted either way ?
    have noticed tonight that the swirl bar has come off all the valves !!
    The third cup has snapped so it wont sit on the drive valve when it moves.
    I have turned the bar 180 degrees and clipped it on the nipples so that the broken cup is now on valve 2.
    will this work properly now till i can get a fix for it or is there only one way to have the bar on the valves ??
    Do the valves turn 360 degress or just move back and forth ?
    cheers
    Regular Member sebadee's Avatar
    macclesfield
    Valve 3 is the one that moves and the bar moves the rest so if it's not connected to number 3 then it's not doing anything
    macclesfield
    Sorry just read your post properly
    He bar is designed to only go on one way but as long as you have reasonable clearance all round and free movement I don't see it being to much of a problem
    Jun 2011
    Liverpool
    just had a quote for new inlet manifold, actuator, sensor,timing belt,
    £ 800 all in.
    said he couldnt give me a warranty for the work without carrying out all the other work.
    Only had the timing belt done last year and i paid about £ 250 for that on its own !
    wish i knew then that it needed doing.
    Think the actual labour is around £ 150 + VAT, he quoted £230 for manifold, £ 170 for actuator, £ 75 for sensor, forgot what he said for the timing belt, total was £ 660 + VAT.
    Engine : 1.9 CDTi
    Tell him you dont need to remove the belt as the pump pulley bolts to the block.
  1. Swirl Bar help please
    By elle2801 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 21:28
  2. Swirl bar
    By 1 hammer in forum Diesel Engine related
    Last Post: 24th October 2012, 21:58
  3. Swirl Bar
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 29th February 2012, 20:14
  4. Swirl x
    By dannyp in forum Detailing and Car Care Discussion
    Last Post: 22nd August 2011, 17:59
  5. swirl or not to swirl
    By lesron in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 19:53
