Results 1 to 2 of 2
Thread: Diesel pump knock
    Regular Member ads3's Avatar
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    confused Diesel pump knock
    Hi,
    2005 2.0dti
    I had a new diesel pump fitted 6 months ago, I am currently having a new turbo fitted and while in, VX have found a knocking coming from the diesel pump at about 2,500rpm but apparently it tends to go when the engine is warm.
    The pump was taken off to investigate and there was some oil in it, the pump was sent to get tested by Bosch and there is no fault so they wont replace it, which is fair enough. The pump has been flushed out and is getting fitted again tomorrow. VX are replacing the injector seals as precaution as this is the only place where oil can enter the pump, is this correct?
    They have said the oil could be from when it was first changed as oil tends to get dumped in when the pump fails.
    Would oil in the pump cause it to knock?
    After reading positive threads on here regarding adding 2-stroke oil to diesel I have been and bought some, along with some Millars, ready for when the Veccy is back but am now worried I will do more harm than good.
    I can't afford any more repairs and I can't afford to P/X the car either.
    I would really welcome your answers, suggestions or comments.
    Thanks.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    well diesel is oil based and loads of ppl have bein adding oil to there diesel BUT old oil has loads of crap in it so id say old oil wouldnt do it any good but i cant say yes or no im just quessing old oil would not be good for it
  1. Increased diesel knock
    By simon987 in forum Engine & Drivetrain
    Last Post: 11th April 2013, 19:47
  2. Diesel Knock and no compression on No.4
    By skip85 in forum Engine & Drivetrain
    Last Post: 10th October 2011, 21:51
  3. diesel knock with reconditioned injectors fitted
    By pugs,signum in forum Engine & Drivetrain
    Last Post: 5th July 2011, 23:11
  4. DIesel Knock
    By Si-SRI in forum Engine & Drivetrain
    Last Post: 9th June 2011, 12:47
  5. "diesel knock" sort of noise
    By mick.n in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 23:11
