Thread: 2006 Vectra C Air Con Fault
    Aug 2010
    Here
    Default 2006 Vectra C Air Con Fault
    My air con has stopped getting cold despite being re-gassed recently. The system was pressure tested and the garage couldn't find any leaks.
    If I turn the air con on, for a minute or hours, it doesn't get cold but when I turn it off I cet a clicking/ticking noise from behind the glove box (I had the fan unit replaced last year because of water damage caused by enging an bay drainage blockage near the pollen filter)
    Does this mean my compressor needs replacing too? I have 2.2 petrol direct with climate control (7 speed fan)
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    When you turn you AC on do the engine revs dip as the pump kicks in? There have been a couple of people had issues with the clutch burning out on the compressor pump.
    Aug 2010
    Here
    No changes in engine revs, but that's always been the case even when air con has been working
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Aug 2010
    Here
    OK, I've been doing some playing and a little bit of digging and I think the clicking is actually coming from the recirc motor. I've only recently had the fan blower motor and assembly replaced and guessing it needed this as well.
    Once thats done I guess I'll have to get air con regassed again and see how long it lasts - hopefully longer than 6 weeks this time
  1. 2006 Signum 2.2 engine fault codes! Help please :)
    By t13con in forum Engine & Drivetrain
    Last Post: 16th January 2011, 16:39
  2. Auto gearbox fault 2006 vectra elite
    By n1nlt in forum Engine & Drivetrain
    Last Post: 9th October 2010, 22:48
  3. what fault code reader for 2006 1.9 cdti 150?
    By learoy69 in forum General Chat
    Last Post: 10th March 2010, 15:51
  4. my new vectra 2006 1.8 sri
    By gangleyshag in forum Quick Photo Album
    Last Post: 1st January 2010, 16:01
