Results 1 to 10 of 17
Thread: Tyre Pressure Sensor
    May 2011
    Bangor, Northern Ireland
    Default Tyre Pressure Sensor
    Have recently been getting a 'check tyre pressure' warning on the wifes 2003 Vectra 2.2i, rear drivers side wheel. The tyres are standard 16inch on alloys.
    It states that the tyre pressure is at approx 26.1 psi, when started from cold, but gradually rises as the tyre heats, until it goes off.
    I have checked the pressure in the tyre and it was at 38 psi ??
    I checked the pressure in the other rear wheel and it was at 37psi ?
    Is it likely that the sensor is knackered or something else ?
    Any help appreciated
    thanks
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Probably the sensor on it's way out. Apparently they have approximately 8 years lifespan before you're supposed to replace them and you're coming up bang on that now.
    I nearly replaced all mine recently when I put new wheels and tyres on, but when told that decided to leave them as I have a year and a half of "official" life span left on mine and they seem fine.
    May 2011
    you are lucky lol,
    They seem an expensive item £32 on ebay each lol
    May 2011
    Is there no way to remove the warning on the displays ?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Only via tech2 to disable the system completly.. why not just change the sensor.. (they are mandatoy on new cars from januar 2012)
    May 2011
    I take it the tyre has to be removed from the rim to fit the sensor ?
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Yes, the sensor has the valve on it, it sits in place of the normal tyre valve.
    Engine : 1.9 CDTi
    Quote Originally Posted by barachello View Post
    Depending what tyre machine it may not need to be fully removed.
    We just break the bead on the outer face and use the rolling wheel to push the tyre down a bit so you can replace it.
    Jun 2011
    Herts
    just wondering when they started fitting these and if they are something an unskilled tyre monkey may just remove and throw away when changing a valve with a new tyre???
    my car has the system and that it flashed up lastyear when i had a puncture.....but it didnt show my tyres were all a bit soft after i used an inflator with a dodgey valve and were all around 30psi instead of 35 as they should be. had all 4 tyres replaced since the puncture and am now a little concerned..
    Engine : 1.9 CDTi
    Its quite obvoius to anyone its not a rubber valve so they shouldnt have thrown it away.:
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. tyre pressure sensor icon
    By danluke1640 in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2012, 22:33
  3. Cheap tyre pressure sensor
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 07:41
  4. Tyre Pressure
    By Riksworld in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2007, 17:16
  5. Tyre pressure for 18s
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2007, 18:01
