Results 1 to 10 of 11
Thread: Rear Tyres worn
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Default Rear Tyres worn
    Just had MOT done.
    One thing advised on was rear tyres worn on inner edge. Each tyre down to about 3 mm. I bought the car about 3 years ago and new tyres were fitted now done about 23k on them.
    No advisory about bushes worn anywhere and I even asked the tester.
    Any ideas what may cause as am a bit worried now.
    Regular Member Jezzy's Avatar
    S.E
    It could be caused by too much negative camber, i.e. the wheels are leaning inwards at the top, which is a common issue on these cars. You'll need a 4 wheel alignment check to confirm that and correct it.
    Berinsfield,Oxford
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    I did look at this from the back and it does look like you describe. How is it adjustable?
    Engine : 1.9 CDTi
    There are ecetric bolts on 2 of the suspension mounting points so they can adjust camber and toe.
    This is one of the locations:
    Regular Member Vauxhall Thru & Thru's Avatar
    May 2008
    Nottingham
    What sort of cost to get this checked out and corrected please?
    I had a tyre blow out apparently due to the same issue...excessive wear on the rear inner edge.
    Should I go to Vauxhall to have this corrected or elsewhere?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If you shop around it will cost from £45 upwards towards £70 sometimes it depends if they make adjustments
    S.E
    Quote Originally Posted by Vauxhall Thru & Thru View Post
    Find a place near to you on this website, they list the places that have the Hunter alignment equipment:
    http://www.alignmycar.co.uk/
    West
    as above... the hunter system is about the best around, providing the operator knows what he/she is doing
    May 2008
    Nottingham
    Just a quick update. I used the website above to find a local place which does full alignment. It took about 10 minutes to get a report on the current set-up, and guess what? Rear camber out by a mile. Also toeing on one side and front left caster slightly out.
    They went on to correct the camber and toe on both sides, and it's much better now - all running within limits. Hopefully this will result in reduced tyre wear.
    Thanks for the help again guys, much appreciated.
    As commented on previously, it is best to have this performed as soon as you take ownership of the vehicle or at the first tyre renewal
    I have had this done every time, and even on new cars, has required adjustment on the first check
    Thereafter checking the front toe is enough to confirm it has not wandered
    If it has, decline the adjustment and go back for a full four wheel alignment adjustment (don't mention the front toe is out)
    Also, recommended after any and all suspension part renewals
  1. part worn tyres
    By luke.oldham in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2013, 10:48
  2. Rear tyres worn REALLY unevenly...What do we think the problem is?
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 28th February 2012, 21:30
  3. For Sale: x3 part worn 235/35/19 tyres
    By Kev_A in forum Parts for sale
    Last Post: 19th July 2011, 21:19
  4. Selling part worn tyres?
    By Gregg in forum General Chat
    Last Post: 9th February 2010, 20:28
  5. worn tyres
    By dazy75 in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2010, 09:19
vectra c rear suspension
vectra c suspension
vectra c suspension kit
