Results 1 to 10 of 13
Thread: need help changing a uec fuse box
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    Default need help changing a uec fuse box
    hi i need to change the uec (underhood electrical center fuse box) i know i need to match the numbers up will it also require programming in ? and has anyone done one.
    if i fit 1 with the same numbers will the car fire up.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    70 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Iirc mhvcb and plasma have the code doesn't need to match
    I was going to do mine as i have a CDTI fusbox that has front fogs but never got round to it, I was told by a technician that you could easily change over fuseboxes and car would start ok the fusebox doesn't have a code as such its coded using chassis number ( afaik that is )
    Irmscher Insignia CDTI 130
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    I've heard that the new one will have to be tech2 cleared and then tech2'd back into the car (but that's only what I've been told, so not really much help).
    leicester
    Trim : Sri xp2
    Mileage : 100000
    i can get 1 tech 2 out from vauxhall breakers on ebay just not sure on putting it into the car would it be a case of putting the chassis number into it.?
    bigmac so i can buy any fuse box dont have to match my numbers then as im being told they do lol also do you know where the ident codes are on the uec.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    leicester
    Trim : Sri xp2
    Mileage : 100000
    Devon
    70 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If your not fitting fog lights then I would maybe go for same car as yours and age, but if you want to enable fog lights you will need a UEC from a SRI with foglights , As said Mark has done this with help from Dean you don't need same ident code.
    Plenty of members have changed CIM's, BCM, DDM, with different ident codes so it will be fine, I was told these are only coded using chassis number and you could get a a used fusebox and just change it over and car would start and run fine but you may get a code stored saying chassis numbers don't match
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    all modules will need to be tech2 cleared out then in before there fitted
    into any car,although modules do have functions in them that your modules
    dont and vice versa so if you fit a module that has a function that the one
    your swapping it for hasnt then your snookered so your best keeping the
    modules the same but there is modules that are upgraded replacement to
    your existing one but you wud need to compare that on epc.
    oh if fitting foglamps etc then you dont need to change the uec as they
    can be wired into the exisitng uec.
    cheers
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by andy.l View Post
    Andy can you explain a bit more? Im in the process of doing mine and although the wires are there and going into the fuse box, ive added the loom and the switch but on trying to activate them im sure it said they were "not present" on tech2. My next course of action was going to be changing the UEC for one out of an Elite.
    Devon
    70 Post(s)
    Vehicle : insignia
    Trim : irmscher
    My old DTI had wiring there for Fogs but my UEC didn't support Foglights, in tech2 it was greyed out me and the tech guy even tried resetting it but it wouldn't activate.
    I know your the wiring Guru Andy but afaik the UEC has to support Front fogs and some UEC's don't so this is why you need to change them.
    I know Mark had wires in his and he couldn't activate them and he changed the UEC to one that did and he could activate them.
    So yes you could add the loom for front fogs and have that going into lower UEC loom but the Top fuse box just unscrews and lifts off this is the part that needs to support the fogs
  1. Fuse fe1
    By Tombird in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2013, 22:05
  2. fuse help
    By MeTaL in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2011, 23:08
  3. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  4. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  5. LPG blows fuse f7 when changing from petrol to lpg
    By jimkilkenny in forum Engine & Drivetrain
    Last Post: 2nd May 2007, 19:29
vauxhall uec ident codes
what fuse is it fir the centre display for a vauxhall vectra c
uec vectra c
do you need vin number fpr vectra rear fuse box
insignia uec wiring
fuse uec
vectra c uec fog lamps
vectra c fuse box
moduł uec vectra c
vauxhall uec coding
uec opel vectra c 2007
vectra c 2007 gasoline uec
1.9 cdti under bonnet fuse block
vectra c replace engine fusebox
