Thread: Petrol Light
    Regular Member Carl83's Avatar
    May 2011
    Basingstoke, Hampshire
    Default Petrol Light
    Morning guys, just a quick one....
    How many miles (roughly) can you get still when the petrol light first goes on?
    Its a new car and I have only filled it up once and its now coming to the end and I want to gauage what I can get to the tank. I have got just over 300 miles so far. Its a 1.8 Club BTW.
    Carl
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    I know you can go about ten miles....I have never pushed it further than that!
    Bristol
    It's usually about a gallon left when the light comes on, so 30-40 miles at a guess.
    Sep 2009
    Audley STAFFS
    this varies from car to car, when my light comes on I have quite a bit of petrol left in,,, over a gallon, its a 61 ltr tank so when the light comes on, fill it right up,for eg if it takes 57 ltrs you had 4 ltrs left in
    Regular Member Craig1985's Avatar
    harwich essex
    I've pushed my 1.9cdti, light on and range shows 38-40 miles. Then when range shows 0 miles I still got another 20 miles. Whoops- it was a tight month :0/
    11 Post(s)
    The light works in two stages.
    It will first come on and stay on.
    Then if you continue to ignore it....
    It will start flashing.
    If you want to gauge what you get to the tank, why not just brim the tank and press the trip reset; then do some miles; then brim the tank again; then get the calculator out to work out the MPG. Handbook tells you the capacity of the tank, and a further calculation will tell you how far a tankful of petrol will take you.
    btw, not good practice to regularly run the tank low of fuel, unless you want to clog your fuel filter up with with debris from the tank.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    petrol light means petrol station asap
  1. Petrol Warning Light Stays On
    By seanp in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2012, 14:03
  2. Low petrol light ?
    By L11Marc in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 08:56
  3. petrol light
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2009, 10:23
  4. Petrol light
    By stec in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2009, 09:06
  5. Petrol Light-How Many Miles???
    By 2.0 DTI SXI in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2007, 11:37
