Results 1 to 10 of 16
Thread: Dash warning light
    May 2011
    Aberdeenshire
    Default Dash warning light
    Alright all?
    I've recently become a vectra owner; a 2006 vectra c sri 1.9 tdci.
    The past few days I've had a warning light come on when I start the engine, it stays on for a few minutes and then goes off. Sometimes if I turn the engine off and start it again the light doesn't come on the second time.
    It's the icon of the car with a spanner through it. In the owners manual it comes under "engine electronics, immobiliser, transmission electronics, diesel fuel filter, fault". Not very specific.
    Just wondering if anyone might be able to sign any more specific light on the possible problem given the behaviour described.
    Cheers,
    Jon.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Change your glow plugs mate
    11 Post(s)
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    had the same problem back in the winter fella changed all 4 glow plugs cleared the problem new glow plugs from vx about £50
    May 2011
    Aberdeenshire
    This sounds like pretty confident advice.
    Thanks, I'll change the plugs asap.
    Much appreciated.
    May 2011
    Aberdeenshire
    Quick update.
    Thought I'd just save some hassle and stick it in the garage to get this done - £144 quoted assuming everything goes right!! Forget that if I can get the plugs for around £50.
    So next question is identifying my engine - how do I do this? Where's the engine code?
    And.... anyone got any good places to get glow plugs from?
    And.... anyone in the area done this before and fancy lending some moral support... i.e. (I don't want to ruin my new car on my own!)....
    Jun 2011
    Liverpool
    are these what you are looking for ?
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...-/300443981380
    i am having the same problem as you with the light on the dashboard.
    I dont know if mine is 8 v or 16 v !! it is the 150 version sri if people could tell me from that .
    I have cleaned my EGR valve, Boost sensor to try and iradicate the fault but to no avail so may try my heater plugs.
    http://www.vectra-c.com/forum/showthread.php?t=92988
    The above how 2 is for the 16 valve engine. If you have the 8 valve engine the job is a bit more involved as it is harder to get access to the glow plugs on that version.
    c4rlos the 150 version is the 16 valve engine.
    Jun 2011
    Liverpool
    Thank you.
    May 2011
    Aberdeenshire
    Great thanks for the links and info.
    I have the sri so must have the 16v engine right?
    Found some plugs on ebay - will take a look in the engine bay tonight to check out what I'm doing and then probably order them and go for it.
    I've been searching on here as well and people seem to say lubricate the plugs for a day or two before trying to take them out... Should I just spray wd40 (or whatever) directly on to the plug where it is screwed in?
  1. warning light on dash
    By tj56 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 14:50
  2. dash warning light
    By graememk in forum Engine & Drivetrain
    Last Post: 1st November 2010, 02:26
  3. dash warning light
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 17:49
  4. Warning light on dash: What could this mean?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2007, 17:20
  5. dash warning light
    By deano in forum Engine & Drivetrain
    Last Post: 10th January 2007, 09:02
