Thread: dump valve z20net remapped engine
    Worksop
    Default dump valve z20net remapped engine
    hi think i ave a weak diaphram on my oe fitted valve is it worth fitting a dump valve or fix the oe one?
    Regular Member Jezzy's Avatar
    S.E
    Fix the original one - I believe you can get a repair kit from Vauxhall.
    Worksop
    yeah deztroyer is going to get me the part no for it if not wots thoughts on a dump valve kit?
    S.E
    They're not for me - the turbo already has a bypass valve that deals with unwanted boost much more effectively than just dumping it - it allows the excess boost to keep the turbo spinning whilst bypassing the cylinders, so when you jump on the gas again the turbo is already spooled up.
    S.E
    Part number for the repair kit is 55558271 I think.
  1. Z20NET and a dump-valve
    By hog in forum Engine & Drivetrain
    Last Post: 16th June 2012, 17:34
  2. Dump valve fitting z20net
    By tomo41 in forum Engine & Drivetrain
    Last Post: 14th July 2011, 13:14
  3. who as a dump valve fitted to there veccie turbo z20net
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2011, 21:35
  4. Dump valve fitting help on z20net
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 21:47
  5. Z20net dump valve Help!!!!
    By dansis in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2010, 14:23
z20net dump valve kit
