Thread: under engine inspection hatch
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    Default under engine inspection hatch
    just remved the hatch from my 03 2.2 dti including the bits that go up the arches to get to the aux belt as its squeeking, im no expert but i couldnt believe all the crud that gets in there and the sub frame looks rusty like its had alot of water on it, is it a bad idea to remove the under tray and maybe give the subframe a lick of paint?
    Nottinghamshire
    I noticed the same thing when I removed my undertray a couple of weeks ago to replace the belt tensioner. I have quickly treated the worst of the rust but it needs a better job when I have more time.
    I think the water splashed up off the road and condensation from the air-con pipes both site on the undertray and rust through the subframe. Mine was most rusted in the rear offside corner which is where the condensation from the air-con pipes that are in with the wiper linkage seems to drain straight on to.
    I was considering either (a) drilling some drain holes in the undertray, (b) seeing if it's possible to put some spacers between the subframe and the undertray (so the subframe is above the water), or (c) leaving the undertray off (it's only for noise regulations so not vital) and doesn't apparently make that much difference to the noise level if left off.
    Aug 2010
    Derbyshire
    Quote Originally Posted by James24 View Post
    I wouldn't, think it aides engine cooling, and protects all your under engine casings etc.
    Mick
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Had my 2.2DTi for 2 years, the undertray was missing when I bought it and I've had no issues with not having one.
    Nottinghamshire
    TBH, I am erring towards modifying the undertray rather than removing it - as stated above, it may have uses other than meeting drive-by noise regulations.
  1. Pre MOT inspection
    By Birchy63 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 16:31
  2. Chain Inspection
    By spennny in forum Engine & Drivetrain
    Last Post: 6th November 2010, 00:55
  3. inspection
    By justyb in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2010, 10:29
  4. Inspection tomorrow......
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2009, 18:55
  5. inspection codes
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 12:43
