Thread: Code reader for a Vectra B?.
    stockport
    Exclamation Code reader for a Vectra B?.
    My son has a vectra B which is showing the EML constantly.I've got an OBD II code reader,but when I try to get it to read any code on his car,it just keeps saying it can't connect etc.Can anyone advise me of a compatible type that will do the job?. FELIXX.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Have you tried the peddle test, as long as its not a 2.2 petrol.
    Regular Member Marcosuk's Avatar
    Fife
    do the paperclip test mate... think u bridge pins 3 & 5 together then read codes.. first 10 flashes = 0 then normal after that..
    north east
    Which code reader have you got ? maybe somone local could pop over with a different code reader ?
    stockport
    Thumbs up
    Quote Originally Posted by roswell View Post
    I've got the U480 type,but it doesn't want to talk to the veccy B .Regarding the paper clip and pedal tests,guess what?,his odometer bulb has blown so you can't see the mileage!!.(Thank's for the thought though anyway folks).FELIXX.
    Fife
    Does the eml not light up?? My code reader ms509 worked on vec b..
    north east
    Iv got a ms509 but the 2 + hours drive to get there probably isnt worth it im sure someone closer will be availble though.
    anyone in the manchester area with a ms509 ?
    Fife
    There bound 2 be someone close who's got op-com or similar
    Mileage : 55000
    Strange you should say that about it not being able to read the "ecu" I had the same with our old Vectra B. But I could read the codes with the paperclip test though.
    stockport
    Talking
    Quote Originally Posted by ed taylor View Post
    Alas no odometer light so can't see the mileage.Thanks to everyone for their input though.I've decided to do a full service from scratch,and clean and eliminate whatever is possible to eliminate as I go along.Then,if that doesn't work it's plan B...........set fire to it!!.FELIXX.
  1. Code Reader for vectra c 120bhp
    By p1aceb0 in forum Engine & Drivetrain
    Last Post: 20th August 2011, 09:56
  2. Right car code reader to Vectra C 2006 ?
    By jukka490 in forum Engine & Drivetrain
    Last Post: 17th April 2011, 21:55
  3. Whatb code reader to buy for vectra sri 150
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 13:55
  4. Vectra 1.9cdti (150) and using U581 code reader
    By markluk in forum Troubleshooting
    Last Post: 6th April 2009, 17:28
  5. Aftermarket fault Code Reader for 06 Vectra
    By pigdog in forum Engine & Drivetrain
    Last Post: 20th August 2007, 23:58
code reader for vectra b
obd reader for vectra b sri 150
