Results 1 to 10 of 13
Thread: AFL playing up - car is squinting
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default AFL playing up - car is squinting
    The AFL light started flashing and upon inspection the passenger side AFL lens is squinting. If I hit it, it starts buzzing and moving a bit, but won't stay in the same position as the other one.
    Ideas?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It had to happen, a signum with a lazy eye
    Has one of the motors maybe jammed?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Probably mate, but how do I check that? Do I have to remove the whole headlight?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    It fixed itself after I drove over a huge pothole on the italian motorway at 130km/h. Good as new now...
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Quote Originally Posted by Celes View Post
    BTW: Replaced the bulbs in my AFLs last year, and tried to understand the mecanics in these lights. Well, I didnt Its very very very thight. Anyway I removed front bumper and then the headlight - surprisingly easy task - done in 10 minutes including searching for all screws. Still all the mecanics is pretty much hidden inside the cluster, who does not look like it is designed to be taken apart... Ill guess the day this mecanics stops working, it will be an expensive day!
    Bent, my name is Bent
    Mods: I polished it in september...
    The insides are fairly easy to understand, on the facelift anyway. One motor moves the whole interior up and down, and another moves the main beam left and right. Combining the two gives full movement and adjustment available. I've got the pictures here should anyone need them...
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The car is squinting again. When I turn the ignition on the lights level up, down, left, right, but the passenger one is a bit retarded and is pointing on the right
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The bad news is that on TIS it stated that it maby the AFL module thats broken when it does that...
    It could just be that it's come off the joint inside the headlight which attaches it to the motor. Take the headlight off, remove the back cover and you should be able to see what's going on...
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Shall do Martin, but do I have to remove the bumper in order to remove the whole headlight?
  1. Been playing again...
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 20:34
  2. just been playing with my wii!!!!
    By BIG NEIL in forum Games Room
    Last Post: 15th September 2008, 14:24
  3. been playing
    By PeteRs in forum The 'Off Topic' room
    Last Post: 11th February 2008, 15:54
  4. No one playing
    By Steel in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 21:38
