Hi All,
First the car detail:
2002 Vectra C 2.2 DTI Y22DTR
About april/may time I replaced both front wheel bearings. I had to replace one of them again under warranty as the bearing was faulty.
About a month ago the ABS/TC light started coming on and off.
Now it is permanently on. A snap-on code reader tells me I have high voltage at both front wheel sensors. I have checked the plugs from the sensors and they are ok with no obvious corrosion or chafing. The multiplug on top of the abs module also appears in good order from what I can see.
Do any of you chaps have any suggestions or ideas as to where to start looking. Im of the understanding that high voltage suggests a wiring/ECU fault.
The codes were C codes if that helps...
Thanks in advance.
Daz
