Thread: rear pads sticking on??
    New Member nickp1975's Avatar
    wolverhampton
    Default rear pads sticking on??
    does anyone else have an issue with what i think is sticking brake pads? the car feels like it is dragging, when going down a hill and putting the car into neutral the car slows down not coasting quicker, and the rear discs seem to get very hot
    nick
    scotland
    sticking caliper mate
    Regular Member kevcdti's Avatar
    North east
    as said sticky calipers mate
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mine did this. Scrubbed a set of rear pads in 9000 miles. Turned out to be the handbrake adjuster....
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    change the calipers buddy - mine did this - was the handbrake that was stuck on!
    managed to find 2 rear calipers from a breakers yard for £50 nicker..
    The rear calipers are the same for hatch's, saloons and estates
    Hope you get on well
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Don't go buying anything until you've stripped it down. Take the caliper off and try screwing the piston in. If it goes in and out easily the caliper is not seized. Clean the pad slides and lubricate with copper grease.
    Next port of call is to remove the rubber slides for the caliper. The caliper can corrode and pushe the rubber out meaning the won't slide.
    I did the above with mine and saved myself 60 odd quid
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I'm having this issue, callipers not seizing, but locks at one side when hamdbrake is applied and will not release, the spring and replacement spring doesn't seem enough to pop off the parking brake, if I disconnect the brake cable however it all seems loose and springs open...
    Where should I start?
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    as John said , take the 2 allen key bolts out and clean up and lub them , this is what the they slide on .
  1. Rear wheel getting warm caliper sticking?
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 17:29
  2. 1.9 CDTi rear caliper sticking
    By Tennants in forum Suspension, Wheels & Brakes
    Last Post: 14th October 2012, 13:06
  3. Rear brakes sticking (vectra)
    By Steve 100 in forum Handling & Braking
    Last Post: 6th July 2012, 08:05
  4. rear brakes sticking
    By eminemme42 in forum Suspension, Wheels & Brakes
    Last Post: 13th March 2012, 21:20
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
rear pads sticking insignia
