Thread: blanking egr
    New Member nickdti's Avatar
    Feb 2011
    kings lynn
    Default blanking egr
    Hi folks, i recently brought a blanking plate an blanked off the egr valve as previously done on my b gsi but on my cdti 150 it has put the emg light on so i take it it cant be done the same ?
    Dartford
    Am I right in thinking someone with tech2 can remove erg from ecu? Thus eliminating engine management light?
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by nickdti View Post
    I have read that on the 1.9 cdti (120) you need to drill a 9mm hole in the middle of the blanking plate to allow some gases to pass which is enough to fool the sensor that it is running ok and does not activate the EML. Not sure if this works on the 150 perhaps someone else can advise
    Feb 2011
    kings lynn
    Well i have since seen the plates with the holes in the middle on the bay, but i have took it out an the light went off after a couple of days.I might get a opcom if ii keep the car an remove the light that way if poss. Thanks for help.
  1. Egr blanking
    By 1 hammer in forum Diesel Engine related
    Last Post: 24th November 2012, 19:40
  2. EGR blanking
    By MattDC in forum Diesel Engine related
    Last Post: 15th March 2012, 10:19
  3. EGR Blanking
    By dc6839 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 21:10
  4. Blanking egr
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2011, 18:21
  5. EGR blanking
    By ctj in forum Engine & Drivetrain
    Last Post: 1st January 2011, 02:17
