Results 1 to 10 of 17
Thread: HELP NEEDED: 3.2 Petrol inner CV Boot gone and possible driveshaft
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default HELP NEEDED: 3.2 Petrol inner CV Boot gone and possible driveshaft
    Hi all,
    both CV inner boots (as per picture) have gone and there appears to shudder under acceleration. Car is a GSI 3.2 preface lift and is on 40mm lowering springs. Tyre wear is even. Both front wheels have the same issue.
    Would this mean that the inner driveshaft bearing has gone or would they just needed to be packed out again with grease and a new CV boot fitted?
    I have not seen both CV boots rip like this before, they do not appear to have split with age. The outer ones are fine and show no sign of age or splitting.
    Any ideas guys?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I noticed mine like this the other day (both sides). I've no idea how long they've been like that for, but the car drives fine with no pulling / noises, etc. Going to get new boots fitted, re-packed with grease and see how it goes..... (Mine's a 2.2 DTi SRi)
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    just been doing my Daihatzu's inner cv boots....both gone ....M.O.t this month ...
    Dean and I opted for the stitch and glue boots in the end ...ones fitted the others going to have to wait as it phishing down now...
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I was wondering if a worn inner driveshaft joint/bearing would cause the CV boots to split like they have identically on both sides
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by soulman View Post
    that might be worth a try, at least if it didnt work we would not have to dismantle it twice
    Northampton
    Engine : A20DTH
    Mileage : 88000
    anyone know how to tell if driveshaft bearing has gone?
    Regular Member Dan.'s Avatar
    milton keynes
    Anyone know if lowering the car would have any effect on the driveshafts, its a bit of a mystery to me and lee why they have split like this, unless the garage who mot'd the car cut the boots?
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    I think if its stupidy low it places extra load on the cv joint as it runs at a more acute angle than its meant to, also aftermarket replacement ones will wear out even quicker than OE ones. I've only heard it mentioned once or twice on here and if you consider the amount of lowered cars the failure rate isnt too high....
    Driveshaft bearings are in fact CV joints you have an inner one (i believe) and an outer one. The outer one if worn will make the 'infamous' clicking on full lock.... Not sure how to check the inner one at all though.
    Thinking about it, i supposed you could hold the driveshaft itself and then try to rotate just the cv joint and see if there is any movement between the two... that would tell you if any of the bearing have ground away and giving a slight movement which would be felt as a 'clunk' on take-off
    milton keynes
    Cheers mate hoping it isnt caused by the car being lowered as im not the only gsi that is lowered 45mm?
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by Dan:) View Post
    well my daihatzu charade is deffinately not lowered lol ...
  1. Boot Trouble , HELP NEEDED
    By Dannyboy2k11 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th February 2013, 22:19
  2. Driveshaft boot split
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 16:50
  3. 2.2 petrol Help needed
    By clightowler in forum Engine & Drivetrain
    Last Post: 12th December 2011, 17:43
  4. Boot help needed!
    By LAZZEE RARSE in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2010, 08:07
  5. 2.2 Petrol Misfire/Stalling Help Needed
    By lfcfan85 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th June 2009, 13:33
vectra cdti inner cv boot
