Results 1 to 10 of 14
Thread: Running VERY lumpy 1.9 cdti 150
    Regular Member kevcdti's Avatar
    North east
    Default Running VERY lumpy 1.9 cdti 150
    Hi after some info if possible to see if anyone has had same sort of problems ?
    Driving along on the motorway at 70 and my spanner light came on aswell as loosing power,the spanner light went out and engine management light has came on,I had power but not alot
    If it was a petrol I'd say I had a plug off
    On tick over the needle sits perfectly straight,but you can hear and feel the car running lumpy even more when trying to accelerate
    I'm at work all week so earliest I'd be able to get the car plugged in would be the weekend and dont want to drive it anywhere incase it does more damage
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have you checked the vac pipes for splits / perishing? This can be enough to put the light on / limp mode
    Northampton
    Engine : A20DTH
    Mileage : 88000
    this is caused by the 3rd injector plug.
    what colour are the plugs on the injectors, yellow or blue?
    If they are yellow then a modified plug for injector 3 will be needed from VX costing £10 or so.
    Its a know fault with the CDTi 150 and caused by airflow over the engine degrading injector no.3 wiring/plug
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sounds like a turbo pipe.
    Have a check there all still connected an no splits.
    North east
    All pipes look fine no splits etc
    Still on a yellow third injector so hopefully this is the problem (fingers crossed)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by kevcdti View Post
    Regardless if the field remedy does not sort the issue the plug still needs to be replaced.My money would be that the modified part will sort your issue. Had the same with mine
    East Ayrshire
    Trim : SRI XP1
    I had similar problem, Try bringing the revs to 1k, if it kicks quite badly then its faulty injectors. Beware tho, I had the new wiring, had to get all 4 injectors refurbed (cost about £120) runs like new now
    North east
    Big thanks to Tony-1977 for popping over and plugging my car in
    Really appreciate it mate
    If I let car run on idle it runs lumpy but while moving the 3rd injector plug the idle runs smooth
    Looks like a trip to vx tomorrow,thanks for help and info guys
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    No probs mate
    Knew as soon as I heard it that it was the injector wiring. Hope you get it sorted soon.
    North east
    All sorted now
    My lights still on will I need that reset or will it possibly go out after a decent run ?
  1. No power & very lumpy running 1.9 cdti
    By phil147 in forum Engine & Drivetrain
    Last Post: 19th June 2013, 17:25
  2. running lumpy
    By bert01909 in forum Engine & Drivetrain
    Last Post: 9th January 2012, 15:10
  3. 1.8vvt running lumpy + eml on
    By Steevo in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2011, 19:54
  4. cdti running really lumpy and no power??
    By richiem in forum Engine & Drivetrain
    Last Post: 7th July 2010, 19:16
  5. 1.9 CDTI Lumpy Running at Idle
    By Dazfoz in forum Engine & Drivetrain
    Last Post: 13th April 2009, 18:23
vectra c 1.9 cdti sri running lumpy
vectra cdti running lumpy
vectra 1.9 cdti rough running
vectra 1.9 cdti wnt run vectra 1.9 one tooth out running lumpy2004 vauxhall vectra 1.9 cdti sri lumpy 1.9cdti runing roughvauxhall vectra 06 sri lumpyvauxhall vectra sri cdti running roughinsgina lumpy enginemy tdi vectra feels lumpyastra 1.9 cdti rough idleastra 1.9cdti lumpy on idelvauxhall astra 1.9 cdti rough running when started1.9 cdti vectra idle issueastra 2005 1.9 cdti shurging on idlevectra 1.9 cdti rough idlevectra 1.9 cdti rough running alternatorwhat makes an insignia tick over lumpy when first startedvectra cdti150 running very richDiesel vauxhall running lumpy on tick over vectra 1.9 150 running lumpy1.9cdti rough idlevectra running roughvauxhall vectra diesel when started runs lumpy
